googleli
- Dec 17, 2008
Hello Guys,
I just received my ES5 last week. Every time I listen to it for more than 2 hrs, the inner part of my right ear starts to hurt (after I take them off, the soreness becomes greater). Is that normal? Will it go away after some time?
Also, I can hear ambient sound like snapping or rubbing fingers with music off.
Helpful advices are appreciated!!
Hey has anyone paired up their ES5s with a Fostex HP P1?
Impressions please?
In my opinion, the ES5 is a good match with the Fostex. Sounds more refined and less forward - mid range more natural. The vocal image is also more focused. If you really like the ES5's forward sound signature and not anything less, don't use it with the HP-P1, but if you are one of those who feels that the ES5 is way too forward without much center focus, the HP-P1 is actually a good match.
I'm not saying it's for sure the cause of the problems you're having, but contrary to what I've heard others say in this thread, there definitely is such a thing as "too tight" a fit. At least for me. I kept seeing people say "tighter is better, your ears will get used to it after a while." And that's what kept me from going back to my audiologist. But after months of not getting used to it and being on the verge of regretting getting ES5s in the first place, I went back. He didn't shave off much, but it was a night and day difference for me. So if you feel that's what it could be, give it a try.
Would it be stupid to use the ES5 for intense exercise -- like long distance running?
Can the unit stand up to that kind of abuse from sweat?
thanks - apologize if this isn't the right forum for this Q.
Moseboy,
Before you do the trimming, did it hurt "after" wearing them?
even worse, try eating with customs in
