rodweb
- Mar 10, 2013
Less than 6 months old....$240-280 range I would say.
Thanks, I'll keep my eyes open
I do not like them. Once on they are almost impossible to remove without ruining. Exit hole is kind of small. I think Comply makes far better tips.
Have anyone tried the Westone's true-fit foam tips?
Recently I bought and received these and I'm very impressed. I'm preferring these over the the black star tips because the isolation is much greater without sacrificing the overall sound, in my opinion (I had tried numbers of tracks and found nothing were changed with the SQ nor the soundstage). Another thing, the star tips make W4 too bright which tires my ears fast, or could be that the star tips don't isolate much so outside sound interfere with the SQ. But with the true-fit, the tonality is just right.
Will test the isolation when I commute / driving car in freeway.
No offense, but it's probably not the best idea to drive with your iems in your ears blocking out the sound of emergency sirens, car horns, and the like.
I've never been able to remove Comply tips without ruining them.
Next time I need foamies I'll try the tru-fits.
