- Aug 2, 2014
I'm running the LCD-4 with the Yggy and the Milo. At first I was concerned that it was a bit bass light and excessive on the treble. My issue was power quality causing hash in the upper treble. After getting the PS Audio P3 and finally getting some clean power, I can say the Milo is beautifully balanced and manhandles the 4s as others have mentioned. I'm coming from the Audio-gd Master 9 which was good, but not as refined as the Milo. I've often wondered myself about the 4s with a tube amp, however I'm finally satisfied (for a while anyway). Take the extra money you would have spent on the Studio Six and get a P3 (on sale for $1500 on music direct right now) if you don't already have clean power.
Certain houses have more problematic power than others. PS Audio does a great job, in comparison to many of the garbage power conditioners from other companies. Honestly, their lower-end models will really get the job done too. I just have a Duet and it fixed very ugly AC problems at my old apartment. That model is discontinued now, but you can get a PS Audio Dectet for $499, which will help with treble, bass, and dynamics and drop the noise floor on any amplifier.
I do also recommend getting nice power cables on either side of that, if you really want that last layer of refinement. I use a high current Pangea AC9-II to run to my Duet (beware, it's not very flexible, but it sounds fantastic) and a Wireworld Electra 7 to run to my amp, as it provides unrestrained dynamics, top-notch musicality, excellent clarity and exceptional refinement overall.
Improvements like this will have improvements on just about any high-end amplifier - though I feel it should be noted that the Wells Amps are far less finicky about power than some others. Cavalli gear, for example, is extremely sensitive to AC power.
