Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
post-14146763
Post #3,436 of 3,580
LaughMoreDaily
Canada
Canada
Can someone post some links for knobs for the Walnut? I've looked but haven't come up with anything... :frowning2:
I heard the hole should be 5 mm and the knob length is 15 mm? Or is that width?
Reactions: vic2vic
post-14146836
Post #3,437 of 3,580
nesty
Checkout your local guitar shops in your area. Those knobs can be found there.
post-14153627
Post #3,439 of 3,580
classicalguy
Can someone please explain (or send me a link) where the USB performance of the available players is described? What resolution files can be played through USB on the newer Walnut, and the Zishua Z1 or Z2 using windows? Thanks.
post-14153821
Post #3,440 of 3,580
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
post-14161046
Post #3,442 of 3,580
classicalguy
post-14385744
Post #3,443 of 3,580
aspire5550
Question: I currently use a KZ ZSR iem and TY Hi-Z ear bud. I want to get the best bang for buck budget usb DAC/AMP. Which is better between Zishan Z2 and walnut v2s?
post-14387278
Post #3,446 of 3,580
aspire5550
You can't reviews an opamp without trying it in different setup.
An opamp can change the sound from brighter to warmer depending on the dap used and it's implementation.
I think when using my zishan z2 as a DAC it actually receive the sound in pcm from the laptop. It's not true DAC . You only benefit from the phone/line out of the zishan. I noticed this when using pulseaudio settings on my Linux laptop. My other dap, the nuansa has both options has DAC: true decoding or only receiving pcm
My guess would be the DAC of your phone is good!
May I know what you meant when you say only benefit from phone/lineout of the zishan?
Is this usng usb to connect laptop to the z2 and using z2 as dac and amp?
I am new and i don't understand some of the things here.
post-14387348
Post #3,447 of 3,580
LaughMoreDaily
Canada
Canada
Thanks for your reply.
Do you mind sharing what are the pros and cons so that I will have an idea of what I'm getting ? Thank you again.
I don't own it. I own the Z3 which is supposed to be the same thing (sort of) but with a screen.
post-14387354
Post #3,448 of 3,580
Themilkman46290
Earth
Earth
I have the zishan z1 and z3 and Walnut v2, and the kz zsr, ty hi z hp150, I would suggest save a few more dollars and getting the z3, it has better volume control as a dap and also works like dac through usb
post-14387374
Post #3,449 of 3,580
aspire5550
So i assume the Z2 should also work as a usb dac, am i right?
Do you see any problem driving the IEMs with the Z3? Because i saw a few comments saying there could be an issue as the output impedence of the zishan z2 are high..
post-14387383
Post #3,450 of 3,580
Themilkman46290
Earth
Earth
Yes they are all 100+ ohm players, you can mod them adding resistors, I want to do it to the z1 and Walnut v2 but have not gotten around to it yet, the problem is the volume pot has a tendency to get too loud too quick, this is why I suggested that z3, it's also 100ohm but it has a lot better volume control for sensitive iems like the zsr, I can't use zsr on z1 or Walnut v2 as players, distortion and volume is too much, they work like amps better but still you have to turn volume up past 35-40 percent and at that point they get a bit of hiss. It's better in the z3, less hiss and lower volume
Reactions: LaughMoreDaily
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
