Do vocals tend to correspond to a certain frequency range? If so, do woodwinds/brass similarly correspond, or perhaps piano rather? Thanks
I am not sure if this is what you are asking. All vocals are in the midrange with overtones going into the treble. I attached the below chart. The Ely handles them well.
As the Piano frequencies range from 27.5hz to 4,186 hz, it covers the mids, high mids, and the bass all the way down to 27.5hz which is pretty close to the lowest most of us can actually hear ( most folks cannot actually hear 20 hz tones from my experience ). This wide range makes it difficult to reproduce with a lifelike presence. The Ely does a good job on it as well, but will lack a bit of low bass punch. Overall though, I think it does a fine job with the instruments you mentioned. Also, as an example of its capability, EDM does not actually go that low, so you might be shocked at how well the Ely can produce it. Tks.
