gimmeheadroom
Exactly, attenuate the positive.
Sorry, no can do--I'm an opinion attenuation resistor.If all else fails perhaps you guys could attenuate your opinions
I've heard about your kind. But I remain non-judgmental........ At least for nowSorry, no can do--I'm an opinion attenuation resistor.
People try to put us down....just because we get get get get get around...I've heard about your kind. But I remain non-judgmental........ At least for now
….talkin’ ‘bout my amplification….People try to put us down....just because we get get get get get around...
I would opine further on this subject, but in reality I would only be putting up an Eminence Front.….talkin’ ‘bout my amplification….
Thanks. Using an iPad into Pegasus, should I set volume on iPad at highest?Most important is using the 4-PIN XLR headphone output to make use of all 4 amplifiers inside.
Play with pregain if you want more volume control range
Use xlr from the Pegasus to the v281
Gain settings are all off at the moment.Most important is using the 4-PIN XLR headphone output to make use of all 4 amplifiers inside.
crackling not clicking. Just makes me jump lol.Thanks. Using an iPad into Pegasus, should I set volume on iPad at highest?
Also, I noticed that there is clicking on headphones when adjusting volume. I read this is common?
Besides using the 4-pin XLR headphone output for best sound, I would advise you to adjust the V281's gain as needed (taking into account the Musician Pegasis' output voltage, which I can't find anywhere) using the dip switches on the back of the unit.Hi all,
I am excited to be expecting delivery today of a V281 to pair with my Musician Pegasus (1250 ohm output impedance) and LCD-3.
I would be grateful for some advice on recommended V281 settings.
Thx
There has been endless speculation on this issue--audible/sonic effects of different gain settings--in this and other headphone amplifier threads.will adjusting gain change things like bass presence etc?
I am using the XLR headphone output on V281, and XLR interconnects from Pegasus to V281.Besides using the 4-pin XLR headphone output for best sound, I would advise you to adjust the V281's gain as needed (taking into account the Musician Pegasis' output voltage, which I can't find anywhere) using the dip switches on the back of the unit.
If you also plan to use the V281 as a preamp (it does superbly well in that role), you can also adjust the separate dipswitch array for preamp gain found inside the case.
