Fegefeuer
- Mar 17, 2011
No need for that at all. Just leave the knob at your favorite position and comfortably turn the V281 on (and off.)
Thanks! Was a little nervous given the power available and what it might do to the headphones. But I guess that's what the relays are for.No need for that at all. Just leave the knob at your favorite position and comfortably turn the V281 on (and off.)
Hi
I recently bought a v281. Very happy with it. I have one basic question regarding the volume. Should I return the volume knob to the zero setting before turning on the unit? I suspect not, given that the manual says "On power-up and power-down, the outputs are cut from the amplifier circuitry by relay".
I just want to be sure. Having set the jumpers, I would prefer just to leave the volume knob at my preferred listening level when powering down and powering up. Anyone heard of any problems with this (headphones will stay connected to the unit as well)?
Cheers, Paul
No, just dont play with gain settings when its on. You need to turn off amp for that.Hi
Cheers, Paul
I totally agree with everything you said. I also have the thx 789 and the violectric 281 to power my moded hifiman He-6 4 screws.
The difference between the two is not significant. I think the hpa 281 offers more body to the sound ,the bass is more precise and tight and it sounds darker overall. Where as the thx 789 sounds a bit thin and bright in comparison. I also noticed that is more neutral than V281.
I think the THX 789 is a killer for the money.
It's a modded HE-6 with classic cups and a HE-560 headband system.
Is this a prototype or a commercial unit ?If you haven't discovered it yet. This was shown at a few recent fairs. This is how future Violectric products in the same range will look. As you can see the case is much wider and deeper so there is place for more electronics. This of course bodes especially well for the V280/281 successors.
Relais volume control editions will sport the same volume control as the Niimbus devices.
The old casing will remain with the current generation. All upcoming devices will have either this case or a smaller version of it depending on the model.
Here you see an upcoming DAC/AMP from Lake People in its full size. The DAC inside is a full blown DAC, no small add on card.
I have no idea about a release but I will open up a thread once I have more info.
