sorry for the late response but it takes me a while to get around to things, I'm the king of procrastinating
tonight I tried to upgrade the opamp to my little-known korean discrete opamp the Audiofeel opa3301
tools needed
1) discrete opamp or at least a nicer ic opamp
2) ic puller(optional, you can always pry the old opamp out with a flathead or something)
3) torx t-8 screwdriver
unfortunately I found out my discrete opamp was too large and tall to fit due to the ribbon cable running over the opamp socket. I could have disconnected the cable and replace the opamp with an ic opamp or a hybrid discrete/ic like the burson v5i but I only had a really big discrete opamp available. In the pics the opamp is the thing wrapped in foil, I haven't removed it from the packaging yet.
as you can see it's too big so I was a total failure as an opamp roller.
On the plus side, I confirmed the dac is 10/10 when it comes to build quality, the circuit boards look extremely thick and all the components look perfectly put into place and brand new stock. I felt like I was lifting the hood of a brand new supercar and looking at the polished and cleaned engine. The panels are extremely thick and the tolerances of the way they fit together is super tight. When I dropped the top plate back into place it made the noise a manhole cover makes when they drop it back into the hole in a movie. All the rear i/o ports are super solid chassis mounted parts with nice hook up wire connecting to the pcb, much better than pcb mounted which rely on soldering to the pcb to stay in place, the type you'd see on cheaper components. Or even some higher end ones.
edit: so I learned probably the nicest opamp upgrade would be either a nice IC opamp or the Burson v5i, which is the one I'd probably try first
here's what a burson v5i hybrid opamp looks like, it's part discrete and part IC and still relatively small.
