Burson Sound Supreme V5I opamps arrived! testing it first in the headphone amp in the dac-r2r-ref.
It's still warming up, haven't listened yet.
Step 1, small medium large opamps. v5i container, v5 container(empty) and audiofeel opa3301 still in foil wrapping
Step 2, The right tools for the job, an ic puller
Step 3: Detach ribbon cable, make sure pin 1 is aligned, in this case the pin 1 dot was in the top right corner, when the volume knobs are on the right and the toroids are on the bottom closest to you. Make sure all 8 legs are in all 8 holes
Step 4: Push the opamp down, make sure the legs go straight into the hole and don't bend. Make sure it's fully seated
Step 5, admire your work. Don't forget to plug the ribbon cable back in.
bonus pic: I swear, I'll find a way to use this giant Audiofeel opa3301 opamp some day. Even with the ribbon cable removed, it wouldn't fit because the pcb of the opamp banged into the capacitor next to the opamp dip8 socket!
