toughnut
- Sep 12, 2008
Posted on IER-Z1R thread,
Since I’m in Singapore currently and a call to Sony Atria confirmed they have Z1R demo back in store, I decided to give it a demo. Battle of Japanese flagship IEMs, Z1R vs FW10K.
Size and weight wise, Z1R both bigger and heavier. Memory wise also a bit finicky than I recall on M9. Fitment no issue for me, stable and secure seal with stock M tip. The IEM surface finishing is not my type, same as Andro S. Look gross with fingerprints and collect scratches like no one biz.
Listening through iPhone X with dongle. Music from Spotify offline highest quality.
First listen, remind me of M9 tuning with bigger stage height, improved sound dynamic and bass texture/decay. More musical version of M9 due to DD bass imho albeit good bass response/impact on M9. 100% can identify it’s dynamic driver from get-go. M9 punch harder (speed sound the same from memory) almost like a dynamic but there’s no reverb/decay unless it’s in the music.
High is a step behind low and mid spectrum, similar to M9. It’s definitely well extended but just not upfront which impact the next aspect. It sound dark, not airy. Listen to Celine Dion doesn’t make me cry.
Noticeable plastic/honky sound (voice, instrument), again similar to M9. Don’t think it’s due to bass bleed. Not severe but compared to my other recent IEM, it’s there. Mid otherwise is fine, not too upfront nor distant. Sound quite similar to M9 but with extra body (DD?).
Soundstage height is better than M9, sound larger. However width almost the same from memory. Overall still sound more intimate compared to 10K/Solaris due to darkness. My issue is the stage sound like an image (let’s say 16:9 format) being drag upward to create illusion of stage (4:3) height instead of original image recorded in that desired resolution. Solaris and 10K are much more convincing, with notes floating in each recorded space.
Separation/layering, better than M9 from memory but 10K seem much precise, easier to pick out each note. Each guitar pick, drum beat etc is clearer on 10K. Solaris also have upper advantage here. Likely due to airiness between notes making much of the differences, affecting overall presentation clarity.
All above may change if Z1R is not driven sufficiently from iPhone (which mostly likely the case as 10K definitely improved when driven by Micro Black Label compared to iPhone). However both straight out of iPhone, I pick 10K any day. YVMV.
