Billheiser
Er.. guys I have a constant hiss gentle crackling sound now in the background. Its barely audible but its there..
Is this to be expected of tube amps?
No. Not normal/expected.
How are the stock tubes? Decent? Or is it better of swapping them? Someone here mentioned the bass being a bit boomy. Which tubes would you recommend to tame it down a bit and have a neutral sound presentation. Im planning on running hd650, hd600, dt880(600Ω), and k701 when my valhalla 2 arrives.
I'd still get a hold of Schiit. If it's new they'll probably swap you tubes.Well.. I think its probably my tubes causing the hiss.
I've ordered the Genalex
Gold Lion 6922
We'll see if that reduces the noise floor..
So issue resolved..
On high gain mode the hiss was present, I switched to low gain and its completely gone.
So using low gain and the 11-12 o clock position for volume
Very happy!!
what? isn't the val2 suppose to be very solid state like for a tube?
