shields arrived!
from this psd
into this shields
the smooth detail the laser machine can do is just astonishing. was a little bit worried how my inverted image would be printed out, apparently it came out vividly like the original image. awesomeness!
but yes, just like someone posted in this forum, you better buy a good allen key. don't use the one included with the shields. it wears the bolts. but luckily (or is it?) the shields comes with 2 (two) black bolts and two silver bolts. so i can replace the most worn bolt.
