guzzler
- Jan 17, 2003
none at all, I bought some 28awg SMD solder, but didn't need it: used 21awg Cardas silver solder excessively then used a desoldering pump to take off the excess. Same as the solder wick technique, but I've never been any good at using desoldering braid. The worst bit was lining the little legs up on the right pads.
The boards are very nicely made, I was recommended the manufacturer by aos and I can only say it was a good recommendation!
edit: yep, battery powered, a steady 5.00V from the first regulator. Didn't want to prod around too much with the multimeter to measure the switching output with big prongs, will do that soon though. I assume the 3.3V output was good as the PCM2702 powered up fine
g
g
