ITZBITZ
- Oct 31, 2003
I'll make a jumper that plugs into the battery connector tonight to see how it works out and report back. Right now, the background is dead silent on my PC that generates audible hum when using the Sonica. The Sonica picks up noise from the power supply on this really crap Dell at work. At home the Sonica is quiet so my high-end supply at home seems to be filtered better. So this will be a good test for me to try out as I have a very dirty PC to check it out on.
Originally Posted by guzzler I've finally worked out how to make it bus powered with a decent quality of supply, and (as always) it's so simple: jumper from a pad on R7 (which is otherwise unused) to the +ve side of the BATT connector. That way the 5V USB power gets stepped up by the switcher then regulated at 5 and 3.3V levels to provide a reasonably clean power source, though probably still not as good as batteries! |
