ITZBITZ
- Oct 31, 2003
NOTE: The regulators can only handle a MAX of 16V, safely I wouldn't go over 12V. So don't plan on powering this from the same supply as a large amplifier without an external regulator to drop down the power first.
Originally Posted by guzzler been thinking about the alternative power supply question, there isn't any need for additional pads for supplies >5V. There are points you can connect straight into, for example, if you don't use the switching supply, >5.1V can be connected to the right hand end of R2 or the bottom of C2. |
