I'm thinking of going with the following
PCM2707 (requires 3.3V supply, in addition to the 5.0Vbus provided by USB) -> AD1896 (3.3V and 5.0V), Df1706 (3.3V part), AD1862 (+/-12V for the analog side, and +/- 5 to 12V for the digital side).
a) The 3.3V PSU for the digital poarts (PCM2707, AD1896, DF1706) would be derived from the +12V PSU for the digital portion of the AD1862, and then a separate +/-12V for the analog portion of the AD1862/I/V stage
OR
b) I could go with a single 3.3V supply to power the PCM2707, AD1896, and DF1706, and have a 5.0V PSU for the AD1896 and the digital side of the AD1862, and then a +/-12V PSU for the analog side of the AD1896.
c) I could go with a 3.3V PSU for the PCM2707, DF1706, and AD1896, plus a 5.0V PSU also for the AD1896, derived from the +/-12V PSU for the AD1862 (ultimately 3.3V derived from the 5.0V, derived from the +12V) for the digital portion; and a separate +/-12V PSU in the for the analog portion.
So for a) I could create a +3.3V PSU from the +/- 5-12V PSU required for the AD1862 (e.g. one transformer), and one +/-12V PSU for the analog side of the AD1862 and the I/V stage (which will be an opamp - probably ths4631).
or for b) I could create a +3.3V needed for the PCM2707, AD1896, and DF1706 from the +/-5V PSU required for the digital portion of the portion of the AD1862; and then a single +/-12V power supply for the analog portion of the AD1862 and the ths4631 opamps used for i/v conversion.
What do you think?
