- Jun 26, 2001
For the record, I've requested via email to be able to search by date added
Funnily enough I have the opposite issue (in a wired sense)...
The LG DAC allows the use of remote through USB, but it only works for pause / stop... The volume control on the cable does nothing.
Ever since the last update I have a problem with album playback. UAPP skips tracks, going from track 1 to 3 to 5 etc, which is very annoying with classical music.
It seems like the app "turns off" after about 10 or 15 minutes of use, and I'm getting a connection error. This doesn't happen when using Tidal or Spotify directly, so I'm assuming it's a bug in the app.
I'm using an LG V10, if that makes a difference.
Thanks!
