Can somebody explain how to get Qobuz running through this app, i know this is possible now thanks to the latest update enabling the ability to use BubbleUPnP with UAPP but I just cannot figure out how to play Qobuz
I'm really enjoying the UAPP app on my onkyo DP-X1 and use it when connecting to my Mojo. I tried the upnp option with bubbleUPNP and managed to get it working with tidal both on my onkyo and using my Samsung tablet as a remote. However I did get some skipping and glitchy playback. One of the things I liked about using bubbleupnp was the ability to access tidal genres.
So now that artists are available on UAPP I'd like to add a feature request to be able to access genres in Tidal. I find this a useful feature to find new albums in specific genres and bypass the rap and pop bias in the new albums category. Thanks.
Rick
Qobuz is not supported yet. I have requested qobuz to be supported, but seems there is a patch that needs to be open up by qobuz. I have sent an email to qobuz as well but no reply.
Question about skips and playback glitches.
I'm sure these are caused by some background Android process eating up CPU cycles. It only happens every once in a while. I do better when I set my Note 4 to Airplane Mode and Do Not Disturb but it still happens every once in a while. Any suggestions on eliminating these or is this an inherent limitation of using a phone as your transport device?
I have an SD card with some DSD albums and FLAC albums. However UAPP cannot see the DSD albums. However if i use file manager to browse to these albums UAPP can play them?
So why cannot these albums be displayed within UAPP app itself?
I believe UAPP gets it's artist/album info from the Android system. Tthere's a pop-up about this the first time you try to browse for content. Click the "?" to see it again.
http://www.head-fi.org/t/704065/usb-audio-recorder-pro-uapp-24-and-32-bit-playback-ubiquitous-usb-audio-support-for-android/345#post_11521783
