superuser1
Just wondering if this will work with the Samsung m30s
Blerg!!!True. That's how Android works I'm afraid.
Hi Davy,
I'm having issue with image + cue type ape files (file compression High). Gapless playback not working proper, some times on lock screen issue with play/pause button, but most annoying ... when I touch seek line. Music stop playin and then starting next track.
Thanks
Guys this issue is only on my device or it connected with latest version?
Couldn't get the value of a gain/volume control! This usually means that the device does not get enough power. Please try with a powered USB hub.
Hello, I recently picked up a chi-fi dongle DAC/amp (different seller, but this is the model). When I connect to UAPP on my Pixel 3 I get an error stating:
Thing is, if I use an app by itself it works just fine (Tidal and Amazon Music). Back on UAPP, I have the MQA add on and when I try to play music on UAPP it says "Cannot resample in bit perfect mode!" I have Upsample set to Off in the UAPP settings.
If I disable bit perfect and play music, it plays, but now it's not bit perfect and MQA doesn't work. Any suggestions to enable bit perfect and have it play?
Hello, thanks for the reply, but I do not believe that is the case. The specs say it supports 32/384. I've connected it to my Mac Mini and it appears to be doing such. I tried a local 24/96 file as well as a 16/44 Tidal stream upsampled to 384 and it played fine and the sample rate changed accordingly in Midi setup. It also seems to be playing at 24/192 using Amazon Music HD on my iPhone.The DAC probably doesn't support a sample rate higher than 48kHz.
Can you please share your settings with DX220 ?UAPP in DX220 is my preference player in Android now... cheers
Hello
I must have done something wrong in the configuration : now UAAP only shows three tabs under "Library" : Albums / Playlists / Genres
How can I get the others (Artist, ...) back ?
(UAAP on DX220)
Yes !Settings, Library, Library Tabs?
Thank youHi,
My DX221mk2 setting just follow what Lurker Suggested as following.
Yes !
I was so easy... But what puzzles me is that I don't remember having changed anything in this menu...???
Thanks anyway
