jumpa
- Feb 23, 2017
It will be so amazing if you could implement amazon hd music in uapp because it sounds sooo good.
hi
i got this app now on my S7 with Qobuz with my Fiio Q Mk2 but how do i play music offline ? when i turn off 4G and Wifi i cant play music even i have music from Qobuz on my SD
oke ty then app no good for meThird parties are not allowed to play offline music for both Tidal and Qobuz
There is no other app than the proprietary to fulfill your requirements.
So you have to use the qobuz app to play offline music.
Sooo true..“Earth will be changed forever when Amazon introduces high quality streaming to the masses,” said rock icon Neil Young.
Gotta love the passion, even despite lacking perspective of a few other little things, like disease, hunger, war, climate change, exploitation...
Hey all! Just upgraded to the Note 10+ and am encountering something that's not really an issue, but is quite annoying. After searching online, and here, I'm not finding if it can be addressed or not.
I'd like to find a way to disable UAPP from automatically starting whenever I plug in either USB-C headphones or the Dragonfly Cobalt. I'd also like to disable to pop up that happens every time I don't select UAPP control it by default. Because of this, I can't plug something in to take a call, or UAPP will automatically start and take over the audio... leaving the call to NOT come through the DAC. If I want to take a call, and UAPP is open, I have to close it first. That's fine. What isn't is that I can't just plug something in and have Android/UAPP not do something about it.
Specifically, I'd like to avoid what's in this screenshot. I appreciate any thoughts.
Thanks for replying!In the Developer Options, do you have "Disable automatic routing to USB audio peripherals" turned On or Off?
I did not have that setting "on". So, I turned it on, and closed UAPP. When I plugged the Cobalt in, the pop up still happened.
BTW, have you listened through the Cobalt yet? It's pretty wow.
Thank you. I did that step before posting my question here. It's what led to that screenshot.Please go into Android settings, Apps, USB Audio Player PRO and clear the app's defaults there (please note that this is not clear data or clear cache).
As it currently appears, I can opt for the pop up every time I plug in, which will keep UAPP from hijacking the audio; or... I can tell the pop up to not ask me again, which will cause UAPP to open every time the DAC is connected.
