Usb 24 192khz M2tech Hiface
Mar 2, 2011 at 8:59 PM Post #1,907 of 1,958
somehow I tried the EVO and it works seamlessly with the drivers, play 24/192 without problem.
however on the hiface, it just does not work.
Mar 10, 2011 at 11:01 PM Post #1,908 of 1,958
Found a posting earlier someone comparing the M2tech and a xonar stx.   I've got a Xonar D2, would i get any improvements by adding this to my system?
Edit: Also I've been looking at the Saffire Pro 24 dsp, any idea how it stacks up? Thanks!
Mar 11, 2011 at 2:31 AM Post #1,909 of 1,958
V-Link looks nice, but the MTech has up to 192K out, which I've been using to drive my main sound system.  So stuck with a solution using drivers, as I am still not aware of affordable driverless 24/192 interfaces...
Dan Clark Audio Make every day a fun day filled with music and friendship! Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
@funCANS MrSpeakers https://danclarkaudio.com info@danclarkaudio.com
Mar 11, 2011 at 7:56 PM Post #1,910 of 1,958
http://shop.mapleshadestore.com/Mapleshade-USB-TO-S_PDIF-Reclocking-Adapter/productinfo/USBADAPTER%2DCL/
"Even highly miniaturized circuits like these suffer from signal-induced internal vibrations. Our Amish woodworkers assemble a beautifully crafted (and ultra-low dielectric absorption) maple enclosure directly to the circuit board, thereby greatly stiffening the board while creating an ample sink for draining internal board vibrations"
Mar 11, 2011 at 8:30 PM Post #1,912 of 1,958
The M2Tech should produce a better signal compared to a consumer level soundcards digital output.  If that is what you are asking?  If you have both sitting around you can do some testing though and decide for yourself.
One of the only reasons I could see for using a soundcard for S/Pdif to a DAC is any features on the card should be avialable through the S/Pdif output also. E.g Dolby routines..etc
Mar 11, 2011 at 9:00 PM Post #1,913 of 1,958
Your Burson only does 24/96 top, though...and there's a 24/192 Tenor chip available, but it requires NDA's to get the datasheet: http://www.google.com/search?&q=tenor%2Bte8802l
 USB2.0 Audio Class v2.0 and v1.0
 2-Inputs supported by one I2S pairs with 24bit /192KHz.
But still no 88.2kHz support I guess, and I'm not sure Windows supports class 2.0
Mar 11, 2011 at 9:23 PM Post #1,914 of 1,958
Burson takes 192K through coax... The Tenor is just for USB...
Inputs:
      1 x USB Connection (Support up to 24bit @ 96Khz with 10ppm low jitter clock)
      1 x Coaxial RCA (Support up to 24bit @ 192Khz)
Mar 11, 2011 at 9:31 PM Post #1,916 of 1,958
Well this is off Burson's specs.
I have had trouble with my 192, and Burson made it clear it's supported on coax.  I'm troubleshooting next week when I'm home, but they indicated if there's any problem I should mail the DAC board back to them.
To be clear, though, I have a main stereo, which I have got 192 working on via the HiFace, which was what I was referring to.  The Burson has been a problem in this regard...
Mar 12, 2011 at 4:05 PM Post #1,917 of 1,958
Thank you very much for the reply... I think I'll end up grabbing one of these, or that evo is looking more and more tempting, maybe I'll think about that one too. Either way, results will be posted !!!
Apr 6, 2011 at 6:02 AM Post #1,918 of 1,958
Windows can support audio class 2.0 through drivers: http://www.usbdacs.com/hs24192/hs24192.html
I don't understand why people are afraid of drivers. Every system uses drivers. On the mac side the build-in system drivers just support usb audio class 2.0 by default. On the windows side you need updated drivers.
Many DACs have updated firmware that you can only get through service. For example the Audiophilleo can be updated through the usb port. So I see drivers more as a possibility than a weakness.
Apr 6, 2011 at 3:05 PM Post #1,919 of 1,958
The reason to be "afraid" of drivers is a) new OS' break them, frequently and b) there's a lag between release of OS and support.  For a smaller company, if they produce a product and go out of business, there's no support, and no assurance of future drivers to maintain function.
Apr 6, 2011 at 3:38 PM Post #1,920 of 1,958
I was checking out the Tweak Geek web site yesterday and they are recommending the Harrison Attenuators for RCA HiFaces.  Is there any downside to using an audio attenuator on a coax cable?
"Attenuators - The hiFace is known to have a pretty high output, too high for some DACS. We have had great success using signal attenuators to get the output to a lower level, and the end result is a smoother sound.
  1. RCA Attenuators - for RCA hiFaces, the Harrison Labs 12 dB RCA line level attenuators are highly recommended."
http://www.tweekgeek.com/_e/Portable_Computer_Audio/product/HiFace/M2Tech_HiFace.htm
