Usb 24 192khz M2tech Hiface
Dec 12, 2016 at 12:04 PM Post #1,951 of 1,958
Well, I disabled everything except hiFace but the real culprit was the audio setting in Link. Switched to auto detect (5.1) and voila!
Games and video seems to work but not music which isn't a big a deal anyway.
Feb 8, 2017 at 5:24 PM Post #1,952 of 1,958
HELP NEEDED.....
Ive been using usb on my dacs till now. im buying a gunjnir multibit and a breeze du-u8 usb to spdif convertor in april. i prefer coax here. im new to coax implementation and have these two questions..
1)is it a matter of importance that the convertor has galvanic isolation built in to offer the same protection that say an intona can. i rarely see this described in the specs as on the breeze unit or other convertors. or is usbisolation something different here. i understand optical is not affected for eg.
2)is a chain as i will be using due to budgetary limits and a believer in keeping things simple okay like this...imac--bridge(du u8 breeze)--gungnir multibit dac. with decent cable connections. is this enough without the need for extra hardware tweaks (psu's ,regens etc) to do a good job. i understand the breeze convertor has excellent feedback low jitter etc.
Feb 8, 2017 at 5:29 PM Post #1,953 of 1,958
I recommend that you take a look at the Singxer F-1 , or X-1. I had the breeze, and the X-1 smokes the breeze in every aspect. By a lot.
Just my $0.02
Cheers
[COLOR=333333]HELP NEEDED.....[/COLOR][COLOR=333333]
[/COLOR][COLOR=333333]Ive been using [/COLOR]usb[COLOR=333333] on my dacs till now. im buying a gunjnir multibit and a breeze du-u8 [/COLOR]usb[COLOR=333333] to spdif convertor in april. i prefer coax here. im new to coax implementation and have these two questions..[/COLOR][COLOR=333333]
[/COLOR][COLOR=333333]1)is it a matter of importance that the convertor has galvanic isolation built in to offer the same protection that say an intona can. i rarely see this described in the specs as on the breeze unit or other convertors. or is [/COLOR]usb[COLOR=333333]isolation something different here. i understand optical is not affected for eg.[/COLOR][COLOR=333333]
[/COLOR][COLOR=333333]2)is a chain as i will be using due to budgetary limits and a believer in keeping things simple okay like this...[/COLOR][COLOR=333333]imac--bridge(du u8 breeze)--gungnir multibit dac. with decent cable connections[/COLOR][COLOR=333333]. is this enough without the need for extra hardware tweaks ([/COLOR]psu[COLOR=333333]'s ,regens etc) to do a good job. i understand the breeze convertor has excellent feedback low [/COLOR]jitter[COLOR=333333] etc.[/COLOR]
Feb 8, 2017 at 5:57 PM Post #1,954 of 1,958
This thing is supposed to rock:
http://www.diyinhk.com/shop/audio-kits/111-xmos-192khz-high-quality-usb-to-spdif-with-ultralow-noise-1uv-regulator-wmanual-power-switch.html
Feb 2, 2023 at 1:46 PM Post #1,956 of 1,958
Hi! I managed to open the HiFace Two box and resolder the usb connector that one of the fixing points on the board had broken.
I thought that the bad contact was causing HiFace Two to stop sending the signal, but the problem remains.
The music is playing on Deezer/QoBuz in Windows 10 and it stops, so I disconnect the usb port and turn it back on and it works again.
Does anyone have any suggestions for resolving the interrupts?
Sep 13, 2023 at 2:39 PM Post #1,958 of 1,958
Hello.
Trying to find a link to the hiFace TWO UAC2 driver. Picked up an old Mojo Mystique v.1 and am having trouble actually finding the drivers themselves. Instead, getting driver downloader promos that do not work!
Windows 8.1 downloads/recognizes the device/driver but will not install it.
