MalVeauX
- Apr 29, 2011
I've been using my ATH M50s for a while now, and I think it's time for an upgrade. Right now I'm using a NuForce uDAC 2 to power my headphones, I would like to keep that, because I really don't want to buy another USB amp/dac. I'm a total bass head, I listen to a lot of hip hop, so lots of bass is a must. Sometimes, I listen to a bit of jazz though. My budget is probably around $200, I don't want to spend too much. Any recommendations are appreciated.
Heya,
Ultrasone HFI 580.
And it's well under budget. It's an upgrade from the M50, in my opinion, in almost all categories, but specifically, in bass, which is what you're looking for. You'll find the headphone more engaging, more fun, more colored, and less boring and flat than the M50, which is neutral. The 580 is not neutral, it's a bass machine with good detail and sound stage. It's excellent for your bass cravings and jazz and everything frankly. And it's not expensive. If you want more, you'll need to look for a used Denon D2000 or Ultrasone Pro 900. Your uDac2 is fine, no need to upgrade there.
Done.
Very best,
