Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Whoops, you're right. It's not portable, although it does have an amped headphone out.
^^ Nope. Its a pure DAC and not a DAC + portable amp like the others in this section.
I got a Nuforce Icon Mobile from a friend in a trade and I have to say it's been working out great!
I'm using it for my Dreamcast, Xbox 360, and television watching and it sounds better than I was expecting. I can hear more detail and a nice tight bassline, things I was missing out on before (though my TVs paltry hp amp). It performs these "secondary" tasks better than my LDI+ (which still sounds better for music). I'd highly recommend it for that use, but I thought it was merely "ok" when I used it from my iPod. My opinion on using it to listen to music is still up in the air, but I will say that if you use it as a DAC/Amp through your computer, it'll fare better. In fact, I think it performs better with my D2000s than my uDac did. I think this is mainly because the amp section is better on this (IMO).
I did all this testing with my D2000s, so your results may vary.
That's what I've been saying, the Icon Mobile is better via the DAC as source than an iPod. And I agree it mates well with the D2000 (in a similar fashion that it mates well with IE8).
You may not believe this, but the uDAC uses almost the exact same headphone amp section as the Icon Mobile. But it sounds a little more forward and brighter in the Icon Mobile, maybe due to the analog input section and DAC section being different.
I just felt there wasn't as much bass with the uDac and it was a bit too bright and forward for my taste. The Mobile seems to be more bassy without the overpowering highs. The uDac may fare well for other headphones, but I felt the D2000s are better suited for the Mobile.
Subscribed and reading! What do you suggest for an HD600, under or around $200? Portability is a huge plus! I know that's asking a lot.
Thanks for the reply! I'm thinking about upping the budget a bit, putting the 3move into my range. Where can I buy it?! Also considering a D10....
Ah, I just read that in my thread I had started. So I'm down to the iBasso D10/6/12? I would like to add some treble or high end sparkle. I've read that the D6 is probably best for that...
