aaDee
- Jun 29, 2010
Loose fitting and color too
¿Has anyone compared the FiiO X5ii to the xDuoo X10? Thanks
Would be quite the giant killer if it got anywhere near the x5ii.
Can't see it, I really can't
Few disadvantages would be it does not resume a song when turned back on and works from the start again, some will complain about the lack EQ but with the right set of headphones for you I personally would say you don't need it.
The X10 does not appear to show album art as far as I can tell but have not paid too much attention to that and I went right for listening.
There does not appear to be gapless playback which I was really hoping for but these are just "niggles" as at this price range you are getting something that sounds that good.
A real bonus I found is the volume increments is very low so you have to crank it to get some power or flick the gain button, I can see this being good for people with really sensitive IEMS.
I will keep listening and using and feeding back hope this helps
Thanks a lot for those impressions. The X10 continues to sound like a winner.
I am a bit annoyed though about the highlighted niggle. I often am listening to 1 or 2 hour long trance tracks, and it bugs me when they are resumed from the beginning (I know that I could probably rockbox the X10 someday, but I wouldn't want to do that unless the SQ is as good as un-rockboxed). Oh well, not the end of the world.
Yes I can see how that would be a bit of a pain but they have aimed for a great sound and I think in the price range they have done flipping awesome.
Hopefully XDuoo will release firmware to correct these little things as it would polish off the X10 perfectly.
