Ultimate Ears UE 900 Discussion and Impressions Thread
post-12331845
Post #4,216 of 4,359
Criss969
So I decided to play around with the 900S tips. Tried a smaller size soft rubber tip - and wow night and day difference! I kept going larger trying to get better isolation/seal the it struck me to go smaller.
I immediately felt the telltale "vacuum" for better word. I have been disappointed in bass. They are still not bass head OEM's but boy what wonderfully detailed and extended bass!!!
What do you mean by this? Using smaller tips for a deeper fit?
post-12333060
Post #4,217 of 4,359
Greutel
  i dont know if i should buy the ue900s on amazon. I want something silky smooth mids and i heard they send out ue900 instead of the ue900s
I hate dull boring sound on my re 400 and i heard these and the re 400 sounds kinda the same
I had both. UE900 is a bit more emotional, but still more suited to analytical listening. The UE900s are too expensive for what they offer, though. 200-250 bucks would be a great price.
post-12333224
Post #4,218 of 4,359
violencer
http://www.accessoryjack.com/logitech-ultimate-ears-ue900s-noise-isolating-in-ear-monitor-headphone-for-iphone-ipad-blue.html
post-12333701
Post #4,219 of 4,359
shacky
Deeper and better seal. I had been trying to force larger size in thinking it wold be better. I still get better isolation with Shure but I realize it was counterintuitive going larger tip for better fit with UE's. I can feel the vacuum/seal now when I insert them. And the softer rubber seems to do the trick - I'm not using the foam tips.
post-12343989
Post #4,223 of 4,359
Criss969
Cable is still intact though, so could probably clue the housing back together. This is the original non unibody version of the UE900.
Oh no! I'm sorry to see this has happened to you. I really hope you can fix it!!
post-12344212
Post #4,224 of 4,359
Greutel
I think it's possible to simply glue it back together as long as the small cable hasn't been damaged.
My used UE900 look like they were fixed this way before i bought them. Sound is great so i don't care.
post-12421514
Post #4,228 of 4,359
IBIubbleTea
Do you guys recommend these? I mainly listen to top hits and I also like some bass. I have used the se215s and they were good but I just wabt to try something new and have an upgrade. Something priced simular to the ue900 would be ideal. Less would be nice
post-12421517
Post #4,229 of 4,359
Greutel
UE900 is great, but makes a huge step towards a balanced signature from your se215, but it still has much bass :)
