Zenbun
- Jul 8, 2012
Well the bass is a LOT more pronounced than my Vsonic GR06, I'll need some time to get used to it. Other than that, they sound very similar so far.
Can someone compare it with the JVC HA-Fxt90?
Those two seem similar, somehow, and are at the same price in Aliexpress.
Hey guys, I have been listening to my new T1-Es for a while now. Decided to compare them to my KC06As using the same source. The KC06A's have a LOT more bass than the T1-Es and have a warmer more full bodied sound. Is this normal?
interesting. i was wanting the kc06a's but went with the t1e's because the general consensus what that the kc06a's lacked bass and soundstage.
tips make a big difference. keep experimenting for that "ah-ha" moment.
Sorry for the vertical photo but too lazy to fix. T1E with my FXT90
Just picked up my T1E and i'm liking my T1E so far. This is my first brief impression and differences i've noticed in comparison to my FXT90 (at least 500hours+).
The two are very very similar. The FXT90 does punch harder and slightly darker and quicker overall. FXT90 has a more slightly thicker and weighty note presentation. Mids is slightly more forward on the T1E. Treble is more natural and slightly more sparkly on the FXT90. Soundstage is very similar. Instrument separation and detailing is slightly better on the FXT90, not enough to make a huge difference if you use them outside. Instruments does sound slightly artificial on the T1E compare to more natural and realistic FXT90.
These two are soo similar that everything is only slightly different ಠ_ಠ and i'm having a tough time trying to determine which is more superior. But maybe i'll notice something when i burn them in.
but for the price that you get T1E for I think it competes well against most things below 150 dollars(CAD). Definitely a good value purchase.
Hi,
I've just received my T1-Es today. I'm thoroughly disappointed.Not with the sound, I think it's very good - as long as I hold the IEMs in my ears. None of the tips gave me a good seal that lasted (it's true that I was unable to fit some of the tips on the T1-Es, the rubber tube seemed to be too tight for some of them). I find that the 'tube' on which you fit the tips on is very short, shorter than my Sennheiser CX200 and Moxpad X3. Has anyone had a similar experience? If yes, were you able to solve it, or did you just give up and sell/return them?
Thanks,
Kofa
Hi,
Note: I only tried them with the cable running straight down, like the blue version here:
Hi,
Thanks,
Kofa
