Ingo
- Aug 16, 2004
Thanks man! I was just worried that I was going to ruin the stylus or something. I kinda knew how it went from seeing people do it on television.
Is there anything wrong with using the cueing lever to lower the tonearm down onto the record? It seems to go much smoother when I do that instead of trying to do it with my hand.
The table sounds better than I expected it to. As indicated in this thread, I have no idea how they're supposed to sound but I was pretty happy that it even played in 2 channel stereo!
I was surprised, however, that the sound was thin and sibiliant instead of being warm and syrupy. I'm guessing this probably has everything to do with the cartridge. I bought a $50 phono-pre at Guitar Center, so I'm sure there's room for improvement there, too.
How exactly do I go about adjusting the fine tuning for the speed of the platter? Do you want the strobe thingy to be still? I didn't really know, so I just took a CD copy of the only album I have in LP and compared and tried to match the pitch.
A few more questions...
Are all turntables uber-susceptable to skipping because of bumpage? I only had to barely breath on the thing to make it kind of skip.
Next...
If I can't find the specs for the cartridge that's on there right now, how do I know where to adjust the counter-weight. I read up on how to zero it horizontally, so I did that and then moved it up just enough so it let's the arm go down instead of floating. I'm sure that there's a good reason to know exactly how much pressure the stylus needs.
Also, what does the skate control do? I think I read that you're supposed to set that at the same number as the counter weight?
Finally...
What would be the overkill line for a cartridge for this turntable? (Sanyo TP-1020). It has a plastic headshell right now, so I'm wondering if it would be worth it to get an aluminum headshell when I get a new cart.
Originally Posted by ralphp@optonline /img/forum/go_quote.gif The "DJ" in a phono cartridge means that the needle and cantilever are constructed so that one can "back spin" the record without harming the needle and cantilever. "Back spinning" is playing or spinning the record backwards in order to locate an exact spot within a track. Also a DJ type cartridge will allow one to "scratch" which is term given when hip-hop and rap DJs move the record back and forth with their hands while the needle is sitting on the record. As to whether a given DJ type is worn or audiophile quality that's something one needs to judge by visual inspection for wear and playing a record with it to hear how it sounds. To play a record: Place the LP on top of the platter, the platter is the large round thing that rotates, so that the small hole in the center of the LP fits over the spindle, the spindle is the little rod in the middle of the platter. Turn on the power, select the proper speed, usually 33 1/3 for 12" LPs and carefully place the tonearm down on the LP near the outside edge. Then listen and enjoy the wonders of analog sound. |
Next...
Finally...
