Loquah
You know behind the scenes we always questioned the battery, because the symptoms that weren't lining up all pointed to a lack of power in some way, the way the stage is closed in and compressed, lacking air, or needing to pump the volume to get detail moving. I had meant to change the battery and I will go ahead and order another. I'm not saying it's a sure fix although it will be the first and logical thing to try. I will go ahead and order one now.
We apprecaite your efforts, I understand the differences are probably sublte enough to play tricks on you.
Exactly. Also knowing which one is which makes it really tricky too because you can't rule out the power of expectations.
Either way, I'm happy to help. I'll try to take some time with the batteries in the opposite amps tomorrow and report back, but it sounds like a different battery will get you sorted. The one in mine is a 650mAh Li-Polymer if you're ordering from somewhere local, otherwise I'm sure Tralucent can hook you up - Gavin is always super helpful!
