Pale Rider
Yes, it is so easy to relax and enjoy the music, and actually more rewarding than comparing equipment. Especially with a red. Sea Smoke Southing is my go-to for listening.
The GSX is quite forward if I recall correctly, that may favour an Audeze pairing.
Comparing the GSX to the d1-dual direct connection would be incredibly useful too, but as you say, time is the bottleneck. I often sit down to compare things and end up enjoying an album with a glass of red instead :¬)
It so happens to be the case that I own both. After receiving the GS-X, I've done some (but not an extensive) comparison between the d1-dual as is, and with the GS-X hooked up. Sound-wise I could not notice any difference with my HD800. I'll leave it up to others to decide whether that is a compliment for the d1-dual, the GS-X or both. Note that I did the same comparison with my Lau and found it to "degrade" the sound coming out of the DAC. I can only describe it as a veil that masqued some of the details that I knew where there but simply couldn't here. @bmichels may or may not confirm my findings
In the end, I've decided to keep the GS-X attached to the d1-dual. While I don't here any sonic differences, there are definitely merits to keeping it in the chain: physical volume knob (not having the d1-dual volume at 100% no longer makes it bit perfect), loop-out connector, multiple headphone output jacks, more room for hard-to-drive headphones, ...
Hi
Hopefully I am not going too much off thread now...
If I am not wrong I saw some of you own a Lumin server/DAC (A1 or S1) and a Totaldac d1-dual DAC.
Possibly someone else tried in the same setup the two of them
I own an Aurender N10 that I am using as a streamer to Totaldac. Unlikely what common sense would suggest I am feeding the digital output of the Aurender to the d1 server (RCA better than XLR...) rather than directly to the d1 dual DAC. I prefer this solution because after extensive trials I hear slightly improved sound...possibly because of signal reclocker through the d1 server (I am not an expert so I can easily say very unreasonable things...)
In a few days I am going to try my friend's Lumin S1 substituting the Aurender for the streamer feature.
Someone told me that Lumin S1 is way more musical than Aurender N10
This is the reason I wanted to complement what I will hear with potential feedbacks from you
Regards and thanks
Fabio
Rob Watts Challenge any Nagra DAC HD or TotalDAC owner :
Originally Posted by bmichels
very good sign indeed.
So now we need a battle between the 3 pretenders for "Best DAC with a Headphone Out" : NAGRA HD DAC, TotalDAC D1-Dual (or Mono) & DAVE. Who will win ?
Rob:
That depends on how one defines best - if best is defined as transparency and musicality then Dave will win easily. I am prepared to bet a brand new Dave against a bottle of Bollinger that Dave will win.
In fact that's way too easy a proposition. I will bet a brand new Mojo against a bottle of beer that Mojo will be more musical and transparent than those DAC's.
If anybody wants to challenge me on this, then PM me, but you will need to bring one of those DAC's (or any other reference class DAC's) to Carmarthen, Wales. Plus a bottle of beer and a bottle of Bollinger.
Rob
Nephrite, did you plug your HD800 into the headphone jack in the rear, or did you use the XLR outputs?
