bboris77
- May 27, 2005
I'm experiencing the same issue. It will stop working out of sudden and sample rate will fix/freeze. Only way to make it work is to power off and reconnect usb. Did you find a solution to it? Optical is fine. Thanks
Just to let you guys know, I have experienced the EXACT same thing on my Topping D70. Was listening to some 96Khz Master track quality files in Tidal. All of a sudden, the sound cut out, but the song appeared to be playing in the application. I switched from USB to optical, and it worked perfectly. Went back to USB, no sound. Tried rebooting the application, no success. As soon as I shut the power off on the back of the unit and turned it back on, it worked perfectly. I wish I had just rebooted my Windows before to see if that would have done the trick. It appears that something caused either the D70 to lock onto the 96Khz sample rate and believe that something was being played thus not allowing any other input to reset/interrupt the datastream. I am wondering if shutting down the source (PC) would have reset the issue, or perhaps turning it off and on is the only solution. I wonder if you guys used Tidal at the time - trying to see what trips it up. I am on the latest XMOS drivers (4.82). I have had the unit for about a month, and this is the first time it happened.
