carlmart
- Apr 22, 2009
I was STRONGLY warned by a friend of mine not to isolate or cut the USB cable ground wire. It may harm the Topping.
Has anyone any news about the upcoming topping A50 ?
D50 receives always some kind of signal through the USB signal cord. Even when the audio software stops playing or you quit the software, the D50 is still awake. Only when you disconnect the USB signal cable from the PC/laptop, the D50 switches off after 30 seconds.So how does the AUTO power off feature work. I have it enabled and yet the DAC never switches itself off, even though there is no signal coming to it. Did anyone managed to get this feature to work?
Yup, indeed. It is quite questionable. I have it connected to desktop PC and it just never goes to sleep.D50 receives always some kind of signal through the USB signal cord. Even when the audio software stops playing or you quit the software, the D50 is still awake. Only when you disconnect the USB signal cable from the PC/laptop, the D50 switches off after 30 seconds.
Of course this is a questionable logic. If you are using laptop, then you might want to disconnect the usb cable and there you have the auto power off. But if you are using desktop setup with the usb cable permanently connected, then this auto power off function is useless, you have to manually turn it off.
The D50 does need the ground wire or it wont sync to PC, so it must be connected somewhere else, it did actually sound noticeable better (more noticeable than taping off vbus at least) but this probably varies from machine to machine, the problem is that after a certain amount of time, could be a minute or an hour, the sound cuts out and it needs DAC needs to be restarted and resynced.
This was a good idea to test, so far it sounds like most of improvement is from totally disconnecting the ground (tested by adding a toggle switch to the external ground wire), but having an external ground wire away from data lines might be a small part of it too... its harder to compare the internal vs external ground wire than because it involves removing and adding a piece of tape to the cable plug's ground.You could experiment with separate ground connection between your audio source and DAC (outside of your USB cable).
Just wanted to say that I didn't have any problems in Win 10 with D50. I didn't install any drivers and the DAC was instantly recognised by Windows and worked without it giving me info on installing any drivers. Anyway, it looks like you got it working now.WELL, got mine today and can't make it to work
WIN10 + Asus360 laptop
D50 serial# 1809+
device drivers 4.14
tried different cables + power supply
laptops USB ports
D50 turns on nicely, menus are ok
device settings:
Topping USB audio device control panel
No device connected
sound settings, no other devices than speakers
WIN10 doesn't recognize D50 at all and can't find it as an audio/usb device
absolutely no communication between laptop and D50...
when i turn D50 manually on it gives "USB" then "unlock" and then menu show in bottom line usb input unlock and turns itself off after a while
edit: unlike manual says, i didn't get notification from windows security to accept drivers, only notification i get is that manuals "to complete etc"-YES
Any help appreciated, thanks
well, **** ME, after testing everything i checked bottom of the power supply.... voltage slide selector was just a touch out of 5V and it gave 3V instead... but why it didn't work at all with another PSU
Got my D50 this morning, I felt that the bass is thicker and the highs a tad more sparkly than the D10 but vocals and mids are pushed back like a U shaped sound. I used optical on D50 and usb with D10 so decided to use 50 with usb as well and completely fixed the problem. I don’t understand why optical had that effect.
So now I’m on USB and they are sounding very close to each other, I’ve only been listening for a few hours so I need more time to pull out the differences but for now I think it’s hard to tell between the two.
Very simple: because optical interface is inferior to coaxial and usb interface. Just that. People think that because it's optical it should be better, but the problem is the interface which is bad. There is a a high quality interface, can't remember the name now (ITT or something) that is as good as coaxial. But I guess it was expensive and manufacturers didn't adopt it.
Power supplies are both linear?
