71 dB
Don't want to be "grammar nazi", but mHz = 0.001 Hz and MHz = 1 000 000 Hz
Please do not ascribe to me some primitive ideas as if I don't understand that converting the wordlength from 16 bit to 24 bit "recreates" extra 8 bits (or that upsampling "recreates" some frequencies). I may have some misconceptions but not as stupid as that.
Let's talk about the wordlength (bit rate) first.
I do understand that these extra bits will be "padded" with zeros. But only initially, because, as we apply more and more processes to audio, these zeros will be quickly replaced with figures other than zeros. After several processes even 64 bit wordlength will probably be not long enough to accurately represent the full result of all computations without rounding it off.
Do you agree that (from the technical, mathematical point of view - let's forget for now the debate whether we can hear it or not) after 16-bit audio is heavily processed by 32-bit or 64-bit plugins, the 24-bit representation of their final computational result will be more accurate/complete than the 16-bit representation? If so, do you agree that it's better to send out to the DAC the signal in 24-bit format rather than 16-bit?
Is crossfade similar to crossfeed?well i use minimum setting crossfade on my TT, sometimes no crossfade
1. You appear to be confusing two different things here: Anti-alias and anti-imaging filters. To comply with Nyquist, we have to remove all freqs above the Nyquist Point to avoid aliasing. With oversampling our Nyquist Point is far higher, this requires a much simpler, cheaper and less damaging analogue filter and also spreads the dither noise over a wider band, much of which is then discarded when a secondary (digital) decimation filter is applied. This is why pro ADCs oversample into the multiple mHz range, commonly somewhere around 22mHz. However, none of this is applicable in our case because what we're dealing with has already been anti-alias filtered and there is nothing above the 22.05kHz Nyquist Point of our 44.1/16 input file/signal!
1a. What Bob is talking about was absolutely true, for a number of years. I sometimes used to run sessions at 96kHz as many plugins operated audibly better at that rate, many/most soft-synths, compressors, some EQs and various others. There is now (and for quite a few years) no benefit to this as the processing power available to plugin developers has increased significantly and the coding is more sophisticated. Most plugins no longer benefit from a higher sample rate and those few which do (such a non-linear analogue modelling plugins), now simply up/down sample where necessary and can apply better filters when doing so. I no longer run sessions higher than 44.1 or 48kHz for audio quality reasons, I do so only if a client requires delivery of a higher sample rate.
2. In your "Step B", if we were to make that assumption, then what you've asserted might have some merit. However, you cannot make that assumption! Those plugins which do legitimately upsample would do so at x2 (either 88.2 or 96kHz) as any theoretical benefits of filters and any non-linear processes are perfectly addressed by those sample rates and going higher is just a waste of processing and potentially less accurate. Those plugins with a fixed sample rate (such as some convolution reverbs and some soft-synths/samplers for example) tend to operate at 96kHz. I know of no plugins which upsample to 176.4kHz legitimately and by "legitimately" I mean processors which upsample to that rate for any reason other than marketing. The only exception to this would be plugin processors designed to deal with intersample peaks, such as true-peak limiters, although some upsample well beyond 176kHz.
3. Your last paragraph; if we don't upsample to 176 and the plugins do automatically upsample 176 then yes, there would be fewer applications of anti-alias filters. BUT:
A. If we're feeding the plugin a signal with no content above 22.05 and if the processor is not creating any content above that freq, then we're applying a smoother, higher frequency filter where there is no frequency content anyway, to a signal which already has (whatever) filter artefacts from being filtered to 22.05kHz to start with.
B. All plugins do not automatically upsample to 176. In the case of a plugin with a fixed sample rate of say 96kHz then: You upsample to 176, adding a filter in the process. The plugin downsamples, processes and upsamples again, adding two more filters to the process. That's the application of 3 filters where if you'd just fed the plugin 44.1 to start with, there would only have been two filters applied.
C. If the plugin does not upsample (and there's no reason to, in most cases) then: You're upsampling for no benefit, adding an unnecessary processing step, an additional filter and risking lower precision by operating at a higher than optimal sample rate.
D. If we were to upsample to 88.2, we'd be adding a filter. If the plugin is operating at 176.4, then it has to upsample from 88.2 to 176.4 and add another filter, then downsample to 88.2 and add another filter. If we'd just fed the plugin 44.1 to start with there would only be two filters applied, rather than three.
4. Your fear of up/down sampling and the effects of applying filters to this process is unwarranted. The filters in plugins today are far superior to those of 15 or so years ago and are audibly transparent.
5. In the case of a DAC oversampling to say 352kHz, then going from 44.1kHz to 352kHz is theoretically better than going from 44.1 to 176 and then from 176 to 352. It's one less processing step and filter application, the same as 3d above.
None of the above is absolutely set in stone, as of course it all depends on the skill/effort of the plugin developer.
G
A crossfade is a kind of audio transition, maybe he got confused.
You now argue just to win this debate ...
Several sentences later you write: "If the plugin is operating at 176.4, then it has to upsample from 88.2 to 176.4 and add another filter, then downsample to 88.2 and add another filter." - So now, just to prove me wrong, you are making the very same assumption which you wouldn't let me make earlier!
you invite us to make the conclusion that upsampling and filtering nowadays is implemented at such high quality level so we don't have to be afraid of any quality loss even when this process is repeated many times over and over again. You imply that upsampling / filtering is either harmless or beneficial.
I still think that upsampling helps plugins do their job better. ... To my knowledge (based on the plugins which I have, and whose manuals I've read), if audio is 44 or 48, most plugins will offer x2 oversampling to improve accuracy or will do it even without asking.
Crosstalk => Unwanted. Happens electronically, audio channels leak to each other.
Crossfeed => Wanted. Happens electronically or acoustically.
Crossfade => One audio clip fades out as another fades in. Unrelated to crossfeed and crosstalk.
You forgot one...
Cross Purposes => The way people discuss things in Sound Science
You forgot one...
