mochill
Still the vocals and natural sound , I have the p1 as well and waiting for the p1max to arrive
I love the (female) vocal too and this crazy fast treble, man, some solo percussions can be soooo stunning in speedy snap and timing. But this fit....no issue with it? Thas no1 reason why im ultra excited about the MAX, it seem more ergonomic (but quite bigger too!)Still the vocals and natural sound , I have the p1 as well and waiting for the p1max to arrive
I don't have issues with fitI love the (female) vocal too and this crazy fast treble, man, some solo percussions can be soooo stunning in speedy snap and timing. But this fit....no issue with it? Thas no1 reason why im ultra excited about the MAX, it seem more ergonomic (but quite bigger too!)
IC what your saying. In that case I would have to agree. I think the P1 needed a tad bit more sub-bass (for a touch of rumble, on that we agree), though not more bass overall IMO. I have not heard the HZSound, but will research it. Thanks for the rec!Don't get me wrong bro, i dont want P1plus to be V shape or U shape bassy....just more extended in sub bass region so it can have minimal rumble or resonance. If it have the bass of HZsound Mirror i would be in heaven! By the way, have you try those HZ marvel? It might be up your alley.
To each their own indeed, since I don't use EQ (to have more reason to collect infinite IEM flavor hehe)
Oh I had fitment issues with the P1 also. I found a way around it (for me). I took an old pair of crappy tips, and cut out the core of one of them (medium to long works best), then cut that in half horizontally, having two cores. Then I put one on each IEM as a spacer to hold the tip out further (the fitment issue with the P1 was the angle but also, and moreso how short the stem was). Now they fit pretty darned good!I love the (female) vocal too and this crazy fast treble, man, some solo percussions can be soooo stunning in speedy snap and timing. But this fit....no issue with it? Thas no1 reason why im ultra excited about the MAX, it seem more ergonomic (but quite bigger too!)
The design looks more normal for the new p1maxOh I had fitment issues with the P1 also. I found a way around it (for me). I took an old pair of crappy tips, and cut out the core of one of them (medium to long works best), then cut that in half horizontally, having two cores. Then I put one on each IEM as a spacer to hold the tip out further (the fitment issue with the P1 was the angle but also, and moreso how short the stem was). Now they fit pretty darned good!
I can see this new style fitting a lot of people better than the previous style, though I think I will miss them being so small (I won't miss them looking like a 4 iron though ). The new ones look pretty big for a single driver.
Yes it does indeed!The design looks more normal for the new p1max
Have you heard the OG P1? If so, how does the bass of the P1 Max compare to those? After watching the video you posted, they seem like something very good for me. I have the 7Hz and while I enjoy them, I also really enjoy the texture and speed of the bass on the P1 (though, as mentioned earlier, could have a bit more sub-bass at the lowest end).My thoughts about the P1 MAX. While they may be appealing to many they just don’t have the bass and lower midrange I’m into.
I have spent days writing a review, I even burned them in for 100 hours. But they are not only missing in the lows, they seem to not offer all that much personality? Meaning they are very “by-the-book” to me. Keep in mind I have not heard the 7Hz or S12. Still for my money the RAPTGO HOOK-X is the way to go.
On a positive note the TINHIFI P1 MAX fits killer! It’s really a sports IEM, with a planar driver! Some people may groove on the tuning but I’m simply not into it.
I hear that! The P1 is the one Tin I own currently.Right! All this is subjective to a fault. I have not heard the TINHIFI P1. The only two TINs I heard was the TINHIFI T5, which was very bad, so bad it doesn’t even make the list of what I own, and the T1S.
The USD $20 TINHIFI T1S.........I love!
https://www.head-fi.org/showcase/tinhifi-t1s-universal-in-ear-monitor.25813/reviews#review-28397
Would you consider the P1 Max to be more resolving then the trn bax? While I'm curious about EST drivers I still like single driver planar IEMs. The most interesting factor about these IEMs is getting the most resolution at an affordable price.
