Redcarmoose
https://www.linsoul.com/collections/all/products/tinhifi-p1-max
TINHIFI
TINHIFI P1 MAX
PRODUCT PRICE
$169.00 USD
14.2mm planar Magnetic driver HiFi In Ear Earphone
From the earliest T2 series to the more recent T3 plus, the growth of the brand TINHIFI is clear for all to see, as is their increasing tuning ability. Three years after the launch of the first Plannar diver IEM P1 to great acclaim, TINHIFI is launching the new Plannar diver IEM- P1 MAX in this spring.
The new P1 MAX will feature a newly developed large 14.2mm Planar Driver compared to its predecessor. This new plannar unit uses a diaphragm of only 2μm thickness, and adopts a double-sided array N52 magnet to generate huge magnetic flux. The most obvious difference will be the significantly reduced thrust requirements. This was the main reason why previous generations of Plannar diver products, such as the P1, P1 plus and P2, had put off many music enthusiasts. This time, the new "lightweight aluminium diaphragm" reduces the weight of the diaphragm. This combination produces excellent dynamic fast response over a wide frequency range with precise junction positioning and provides excellent audio detail and clarity, suitable for pop vocals, chamber strings, and The "diaphragm" reduces the weight of the diaphragm.
At the same time, the P1 MAX will feature a new cavity design, with a special acoustic designed structure to provide a wider soundstage and a perfect musical atmosphere.
The lightweight resin shell and fully hand-crafted panel also combine the supreme comfort and elegance.
The extremely high quality 108 core high purity OCC cable will also ensure the highest fidelity of sound with a warm and natural musical appeal.
You can pre order your P1 MAX Here.
TINHIFI
TINHIFI P1 MAX
PRODUCT PRICE
$169.00 USD
- 14.2mm Planar Driver, A New Planar Choice
- Advanced Acoustic Structure, Full Of Details
- Comfortable To Wear
- High-Quality Cable, Interchangeable Wire Design
P1 MAX uses 14.2MM planar drive unit, uses a diaphragm of only 2μm thickness, and adopts a double-sided array N52 magnet to generate huge magnetic flux. The "lightweight aluminum diaphragm" reduces the weight of the diaphragm. This combination produces excellent dynamic fast response over a wide frequency range with precise junction positioning and provides excellent audio detail and clarity, suitable for pop vocals, chamber strings, and many other music types.Elegant Design
TINHIFI P1 MAX's shell is made from lightweight resin and the panels are hand-crafted using a 3D-printed stainless steel torch wire drawing process, with a high-gloss-like jewel finish. P1 MAX is not only a good companion for music but also your decoration!Advanced Acoustic Structure, Full Of Details
TINHIFI P1 MAX displays each detail thorough with a unique acoustic structure, with a wide sound field, bringing a full-bodied and natural listening experience that makes people revel in the music world.Comfortable To Wear
Ergonomic design, the earset weighs only 4.8g and feels "free" when wearing. The earphone is molded based on professional ear canal data analysis. The special shape is comfortable for a long time to wear too and at the same time, it can increase the passive noise reduction effect. It’s improved by adjusting the angle and position of the sound tube to the ear canal, achieving a high fit.High-Quality Cable, Interchangeable Wire Design
Adopting 108 single crystal copper wire core, the sound is warm and natural, the background is clean, three frequency is uniform. Two pins changeable thread design is adopted, can be replaced with other earphone wire, get more sound quality experience. It provides 2pin connectors, matching the mainstream IEM in the market.
