Tidal Lossless Streaming
May 8, 2020 at 9:19 AM Post #4,411 of 5,203
Anyone has problems with opening tidal on windows 10? It happens quite often that the window doesn't open. I try to close the task on windows, and it has worked before but not all the time.
Anyone has the same problem or know a solution?
May 8, 2020 at 9:33 AM Post #4,412 of 5,203
I guess it is just a matter of being patient for the window to open. I have a pretty zippy PC with a fast NVMe drive and it takes about 6 seconds for the window to open. On a slightly slower machine it might take a few seconds more and if you click to open again while that's happening, there's trouble. Have got the latest Tidal update?
May 8, 2020 at 9:44 AM Post #4,413 of 5,203
That's not the problem, because i've waited an hour now :) and i just installed the latest update a few days ago.
May 8, 2020 at 9:57 AM Post #4,415 of 5,203
Looking for uninstall i found 'run as administrator' and now it opened. I'm sure it will happen again though. Thanks guys
May 13, 2020 at 10:35 AM Post #4,416 of 5,203
Latest update has minimize to tray option! Works nicely.
May 20, 2020 at 9:22 PM Post #4,417 of 5,203
Using Tidal on FiiO M 11 Pro...
when I physically move to another WiFi router, Tidal says "Cannot Connect, Tap To Refresh", but it does not connect to the new router. I have to force stop Tidal, and restart before it connect to the new router. Any known solution?
Jun 2, 2020 at 12:04 AM Post #4,420 of 5,203
my pc keeps crashing when i turn on use exclusive mode on tidal. anyone knows how to fix this problem?
or sometimes i can turn it on but when i play a song thats when it crashes.
Have you tried reinstalling Tidal?
Jun 3, 2020 at 12:10 PM Post #4,422 of 5,203
Wow, exclusive mode makes a world of difference with Tidal. Just now I wasn't aware exclusive mode was off, and it sounded flat and less dynamic, and I realized exclusive mode was off! This is crazy!
Few things immediate I noticed when I changed to exclusive or bit-perfect mode. More bass impact, more dynamic, more details, and better spatial imaging of the sound stage.
Jun 3, 2020 at 12:13 PM Post #4,423 of 5,203
I think you can't even get MQA without exclusive mode. Are you using MQA?
Jun 3, 2020 at 12:15 PM Post #4,424 of 5,203
Jun 3, 2020 at 12:19 PM Post #4,425 of 5,203
No, I don't care for MQA. I'm just referring to general music tracks MQA or not. 16/44 is just fine.
I'm just talking about the Tidal desktop app outputs it's signal. It's significantly different with exclusive mode.
Yes, I have had it set on from day one. I use MQA and I think MQA requires it and fixed (max) output levels, so it kinda suggests not having exclusive mode means you don't get a bit-perfect stream.
