maninthehighcastle
The 203 and 205 can play gapless with roon but not with normal upnp. The chip does not support it. Roon use their own protocol.
We're talking about Tidal gapless here which you won't play over SMB or direct attached drives. Upnp with oppo does not support gapless. Roon does.
Just listened to that (the last two tracks on the unexpanded album, right?) and heard a noticeable a gap. I listened through headphones plugged into my computer using the most recent version of the Tidal desktop app for Windows as well as my browser (Chrome).
Further experimentation - I listened to the same two tracks on my iPad using the Tidal app - terrible gap - worse than on the Win 10 machine.
Then I listened to the same tracks on my iPad using the Tidal plug-in for LMS - either no gap or such a tiny one as to make no difference. (I thought there might be a hiccup, but there was no break in the music. Maybe if I knew the album . . .)
I can see why this is a continuing topic for discussion.
True that!
Tidal does not play gapless on Oppo, same story on my Oppo 103 by the way.
Since gimmeheadroom said his Oppo 205 did play gapless I assumed you were not talking about Tidal gapless.
Sorry for the confusion.
Tidal certainly plays gapless using the Windows Tidal app over USB to my Oppo 205 and to my Audiolab USB DAC. I don't remember any delay over SMB or dlna, I can check later.
Yes it does, but that is not what maninthehighcastle and I meant. We were talking about Tidal which is already integraded in the Oppo players and playing it from there. This is 100% NOT gapless.
https://www.oppodigital.com/blu-ray-udp-203/blu-ray-UDP-20x-Firmware.aspx
Product Support
OPPO UDP-203/205 Ultra Blu-ray Disc Player Firmware Version History
Main Version UDP20X-50-0913
Release Date: September 13, 2017
Loader Version:
TF0033
MCU Version:
MCU203-01-1118 (UDP-203), MCU205-01-1220 (UDP-205)
Download/Installation
Release Notes:
- Added support for Roon. The UDP-203 and UDP-205 are now Roon Ready network players.
- Added HDR10 support for the HDMI input. An HDMI In Specs setting has also been added to the Setup Menu.
- Added the Gapless Playback setting in the Setup Menu to set the gapless playback mode for music files.
- Added support for the 21:9 aspect ratio for increased compatibility with 21:9 screen users.
- Improved compatibility with certain models of Seagate hard drives.
- Improved compatibility with Audirvana Plus.
- General fixes and disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted samples.
Stubborn? For Music FILES. We are in the TIDAL Thread, so please stop comparing apples with pears.
If you're using the oppo as the output device of you pc the pc does the playback..
Yes, the regular album. I just listened to 7/8 transition on my phone, Android Tidal app. Absolutely no gap.
The native apps will likely have the best chance for low latency, web versions will be the worst. I have a very fast internet connection.
There is a timer that shows how long the track is. Do you notice the gap at the end after the track counter shows the max. time or at the beginning of the next track? Where is the delay? During the transition, or from when it hits 0 at the beginning of the next track is there a delay until that starts?
At the end of the the the first track, both on the Windows app and the Chrome browser..
I keep thinking that those of us who can, should record the transition (via analog) and upload them, so we know what others are hearing. Not sure how to upload a sound file to this forum, and I've never uploaded to something like SoundCloud. I could upload to my Dropbox unless anyone has a better suggestion. I suggest we all use the same tracks - the Teena Marie tracks are fine.
