So considering that I got a 1S unit with a bad battery, should I contact theBIT directly, or MusicTeck for a replacement considering that I am still within the manufacturers warranty period?
Seems like a faster process directly through The Bit. Then again, at the time mine needed replacement, MusicTeck was sending out a large batch, so it might be quicker with a single dap.
Contact music teck first, they are the official seller, and if you're within warranty, they should serve it before thebit. There were a few bad units of 1s in one batch, most of them were in USA, most other Opus DAPs were okay AFAIK
IEMs aside, I find that this player has a hard time driving low impedance cans, (Grado RS1i) in my case. Plugged that in today and even at medium gain, it feels a bit deflated and out of breath. Anyone experience this?
Why not use it in high gain? I have no issues driving all of my cans to full potential. 3.2 vrms in single ended, 3.4 in balanced. That's a lot of power for a dap. One of the main reasons I chose it. Unless the Grados are harder to drive than the specs suggest, it shouldn't be a problem.
u can contact the bit, search it in google, they will send you the complete address so that u can send your device for battery replacement. it will cost you 32$ and they will return it free shipping once done. i have mine replaced a month ago gudluck
