Like many Dap's I have seen on various sites ibasso products are not available in Canada. No distributor. By the time I imported one from somewhere outside Canada the price would be another 50% higher, what with currency exchange, hst (vat), processing fees and returning a faulty one is even more. Not worth it. The Sony and A&K are readily available along with Fiio but that's about it. Opus no longer is available, I guess the distributor got tired of refunding money and sending them back.Have you considered iBasso DX120?
https://www.audiophile-heaven.com/2019/02/little-joy-ibasso-dx120-review.html
thebit Opus#1S DAP impressions
Dobrescu George
Reviewer: AudiophileHeaven
Interesting, maybe you can ask iBasso directly about that
I have no info on what is available to each region, but it should be available there as well
i have written two mails to ibasso and musicteck. they are aware of this problem and will no longer sell the batch with the problematic batteries. yesterday musicteck has deleted the ebay auction from opus#1s.
new ones will arrive at march according to musicteck.
very fast reply to my emails. seems like good customer support.
Dobrescu George
Yep, Music Teck are very responsible with their players and customers
Yes, but as I pointed to earlier who's to say their not replacing it with the same crappy battery? So I guess at least you will get another 9 months of use out of it. It would be nice to know if they are replacing it with a better, solid battery.
Did you ask? They have been pretty solid in fixing problems with them (or at least that has been my experience as I had a bad 2.5mm connection on mine originally) and I would think they are smart enough to know that if a lot of batteries is bad it should be discarded rather than just continuing to generate unhappy customers and more work for their warranty department. I know it is a concern but I think it is easily addressed by simply sending an email. You might even ask if they would install a customer supplied battery if you wanted to specify a Panasonic made cell.
I liked the SR15 when I got a chance to listen to one briefly and I think A&K does a good job with the interface on most of their players so it is hard to argue against them on anything other than price. I haven't gotten a chance to try the Sony yet so can't comment on that one. I do like the looks of it, but like you have heard a few mixed comments especially as regards use with high sensitivity iems.
Mhog55
Indeed. They said that a certain batch of these devices received bad batteries, and a chunk of those went to MusicTeck. They are using different batteries as replacements, however it is unclear if it's the same style battery, or something different.Did you ask? They have been pretty solid in fixing problems with them (or at least that has been my experience as I had a bad 2.5mm connection on mine originally) and I would think they are smart enough to know that if a lot of batteries is bad it should be discarded rather than just continuing to generate unhappy customers and more work for their warranty department. I know it is a concern but I think it is easily addressed by simply sending an email. You might even ask if they would install a customer supplied battery if you wanted to specify a Panasonic made cell.
CoFire
- Dec 5, 2015
Is this anything that can be identified by serial numbers?
Mhog55
Maybe? You would need to get in touch with The Bit I'd imagine. If you purchased it from MusicTeck, just assume you got one perhaps.Is this anything that can be identified by serial numbers?
I just got the Sony NW-ZX300 the other day. I ordered an adapter for balanced and it arrived the next day. The reports about hiss are not true. There is no hiss or any other background noise for that matter. The sound quality is remarkable. Same ciem's used on both players. The difference in sound is immediately noticeable. Mind you it cost $200 Cdn more but on first impressions well worth it. The battery seems to last forever before charging.I liked the SR15 when I got a chance to listen to one briefly and I think A&K does a good job with the interface on most of their players so it is hard to argue against them on anything other than price. I haven't gotten a chance to try the Sony yet so can't comment on that one. I do like the looks of it, but like you have heard a few mixed comments especially as regards use with high sensitivity iems.
Is there any Dealer in Europe for this DAP?
Another Question: Will they realise something new in the near Future?
borjok536
- Aug 29, 2009
Does anyone here has the picture of the player's battery? What does it look like. I have an opus1s but have just discovered that the back is bulging, and the back cover ajarred and i guess it needs a replacement asap. I emailed thebit regarding this but i have not received a response yet. I think replacing it is not that difficult.
Mhog55
They will respond. Just give them a bit - no pun intended. I believe you need a special tool, or something similar to open the device without causing damage. Plus you may have a hard time finding an appropriate battery. It would be much less painless to send it to them for a new battery.Does anyone here has the picture of the player's battery? What does it look like. I have an opus1s but have just discovered that the back is bulging, and the back cover ajarred and i guess it needs a replacement asap. I emailed thebit regarding this but i have not received a response yet. I think replacing it is not that difficult.
borjok536
- Aug 29, 2009
I have no choice but to send the unit to Korea. Its hard when u cant buy the battery only and it can be replaced very easily.. Our country has very strict regulations on buying battery overseas.. I hope i will not pay dues and other taxes and if that is the case i will end up like buying a brand new opus#1s again.. tsk tsk
gmahler2u
- Dec 19, 2011
Looks like the bit haven't figured battery problem...I don't see on Amazon or Ebay..
