Merlin-PT
- Jan 21, 2005
1. Personally I didn't experience any HW eletronics "burn in" after a mod I've done in zishan.Hello ! I am Looking for the people who own the same device Or similar. It’s dual AK4497. I had it moded by Sanmigel. He completely replaced the composite part as far as I know. Here are graphs kindly provided by Sanmigel.
http://player.ru/showthread.php?t=180748&p=3130287&viewfull=1#post3130287
Questions :
- After the mod it sounds better , but still harsh, will this harsh sound go away after burning in?
- Can’t find the firmware source, that’s ridiculous, is there a manufacturer who created this player, who must have firmware? I’d like to compare different firmware versions, how they sound, they may affect SQ as it was the case with Ibasso dx90.
- Is it normal for this DSDs that it wont connect to PC as a storage? Only usb DAC function working, and music is transferred dedicated through sd card.
- Who can share their expressions about sound stage, stereo width , etc? I am comparing this dsds with dx90 which is currently on the most musical but glitchy fw 2.0. And I must admit the dx90 sounding wider, softer, more highs, but less bass though. Thus comes the question, looking at those excellent parameters and graphs, by all logic, It is supposed sound better but subjectively doesn’t . Or it’s a matter of time and burn-in process, and FW as the experience proves. Has anyone compared the stereo width of these 2 players? Also by means of precise equipment.
- Thanks a lot for your inputs!
In the occasionally (only 2 or 3 times) the sound was harsh and changed after a mod I did, I attribute it to the PCB washing still drying or PCB still dirty and it disappeared after a good wash and dry.
There are combinations of HW componets, bright headphones and source recordings that can produce a not melodic sound. Maybe the unit was modded/tunned with more melodic less dry headphones, I really don't know.
Regarding the headphones burn in, then yes, in some units the sound changes a lot for the better after the burn in, in some others there's no noticeable change.
2. Firmware source for your player is a baidu link and was supplied by Aliexpress sellers.
You could ask the shop were you bought it about the FW source or try here: https://www.head-fi.org/threads/the-zishan-dsds-corner.826185/page-184#post-15653842
3. Yes. Personally I use fast microsd cards around >90MB/s and a fast USB3.x microsd adapter.
I don't have that player. Maybe others will have more to share.
