Well, the bottom plate has only 6 screws, nothing attached to it and easy to remove so off it went. I expected to see very cheap caps but they look pretty decent actually; black & gold series Nichicons and black Rubycons.
The cheapest ones are usually blue...
I think i will leave it alone.
Edit: my unit is the new version, purchased 11 months ago. The boards show V2.2
Onik, i located the photo you posted of the modded WA2, see link below. If you open the link you will see the parts listed just under the photo, here they are:
Jensen .22uF
Sic Safco 470uF
Sprague 330uF
BHC 100uF
IR HEXFRED
RIFA 120uF
Has anyone tried the WA2 with the Audeze LCD-4 (200 ohms / 97dB per mw)? At 14 ohms (90dB per mw), the new LCD-5 looks to be out of the question with the WA2.
Edit: academic question now….Audeze has discontinued the LCD-4…
I guess the question is will replacing the coupling caps change the overall character and sound signature of the WA2. I have my doubts to be honest but i would be thrilled to be proven wrong.
After doing some research I found, that Replacing The two white caps with some Copper Foil Paper Oil Caps will make huge difference to the sound. I assume they are the output coupling caps.
Could't see the back side of the output board, so not 100% sure. But I'm 100% sure on the white inter-stage coupling caps, and 90% positive on the said output coupling caps.
There are audible differences by rolling these passive components (caps, resistors, etc), but not as pronounced as those active components, such as tubes. So from that I will say lots of caps are way overpriced.
I researched these white coupling caps and they are actually 'suppression film' capacitors, meant to reduce emission and increase the immunity of radio and electromagnetic interference. Thus i'm not sure how much of an impact they have on SQ.
Perhaps replacing the 'output' coupling caps instead would yield more SQ improvement, but i'm just guessing at this point. I believe this amp has been around since 2008, surely there MUST be someone who tinkered/upgraded the caps who could speak for the results...
