blotmouse
Sure, I'll do my best to sum it up as i hear it.Your the man I’m looking for
Could you tell me more about their tuning?
The Ti is brighter, more mid-bass focused, and has less control of the bass. Works for or against it depending on what you need.
The Ti is also less detailed and can sometimes border on reflective (treble) using the sharp filter, which add's the most digital vibe but adds the largest staging and best imaging. You can mitigate this by using the slow filter but the slow filter intimates the presentation quite a bit, and is closer to an NOS implementation. Which I just discovered I LOVE with Fourte and hip-hop albums. The stage on Fourte is big enough it can take the hit on width and it smooths out all the raspy throaty vocals and compressed effects giving them the room to sound like the effect is supposed to in space, instead of a digitized approximation with glare. (AKM and ESS has big problems here)
N8ii is more powerful/muscular, transparent, and has the higher degree of sound tweaking available. Some folks hear it as bright, but I am coming from the Ti, so it is actually less aggressive in treble on my iem's.
It's options are actually almost perfect for my tweaking needs. It maintains it's color and personality but can maneuver in and out of the detail transients (my jam). I don't need a whole new dac and amp, I wont change it becasue its a PITA to mess with physical HW when I need a quick sound alteration. I have yet to not find a setting that works on it (unless the material just does better with completely different tech like r-2r) I use all settings combinations, just some more than others.
The voltage rail swing of P to P+ is by far the most pronounced tweak with a stage stretch horizontally and an added midrange push, approximating more of a "W" sound (within the parameters of keeping things relatively similar sounding)
The ROHM chips are the best DS dac's I've heard if you value musicality, reverbs, and spacial imaging. They do this cleaner than the discreet r-2r in the Ti, even though there are some albums I still prefer the Ti for to get that last bit of analogue roundness.
Class A/AB change is very subtle. A is warmer, sweeter, and pronounces tonal peaks. AB spreads the image by giving it a seemingly larger stage with more even harmonics and smooths those tonal peaks that A highlights.
Of note is the tonal balance of the N8ii. Nothing is weighted higher than anything else. It's flat but extremely musical and thick and textured. At first its a strange listen.
The Ti with fast filter is skewed a bit towards a very gentle "V" shape with it's smooth and effortless treble and big round thumpy mid-bass. The mids are not pushed back but they are less an apparent highlight. The smooth filter has more midrange focus. An "A" shape, if only in spirit.
There are outliers of course, but I use the Ti for Jazz and indy rock/classic rock and singer songwriter stuff. I use the N8ii for metal, electronic, pop, hip hop, ambient, experimental. My iem's are now completely modular and they pair well with all my sources. Just depends on what I think the material is conveyed best on.
Hope that helps a little bit. If you want to know anything else specifically, let me know.
edit; lmao I didn't even talk about the tubes. N8ii has tubes. They are super great. The N8ii tubes are like melted glass that gives you all the syrupy goo but doesn't take away from the overall clean tonality by adding too much distortions and warmth. Not that I don't like tubes that add a warming character, N8ii just goes super hi-fi style tube amp, not the usual token warmth route.
