Jeff.h
- Sep 13, 2005
P.S - Your post & pics are making me want to just go buy a pair of these, and I damn well might....
If only I wasn't such a one-phone kind of guy
And Spaceage, I am talking from experience with the headbands
The parts where the sides of the headband meet the middle part, you'll see the plastic of the middle part overlap the side parts a bit. This is usually the first part to go as the placing them on and off of your head causes this plastic to expand over time and one day it usually forms a small crack. Then further expansion occurs each time you put the phones on/take them off, and the crack slowly gets bigger.
The other super common one is those two panels you see on the underside of the headband. The part where the two screws go into the headband is EXTREMELY flimsy, if this cracks it will slowly expand until this piece falls off. When this happens that side of the headband begins to come loose and you are forced to electrical tape it to salvage.
So those are the two ares to look out for. And a heads-up, if you do happen to crack one of those bottom panels and see this early on, I have a replacement piece for it that Ultrasone charged me $30 for. Unfortunately my headband was too far gone by the time I got it to salvage it, so if you ever need that piece PM me and I'll send it to you for free as long as you pay the shipping
