If it is diffuse-field equalized and you have a main cable that splits into two ones to reach both cups how do you make the mix of the signal? Into the big conector? I believe it could be very tricky to change this cable...
The Sennheiser HD 800: The First Listen, The First Review
- Thread starter jude
Jigglybootch
- Feb 5, 2004
The $700 I talked myself out of spending could be used toward the purchase of the HD800, should I decide to go that route.
ericj
- Aug 2, 2005
When they say "DF equalized" they mean the headphone's acoustics are tuned to some resemblance of a DF curve. Not that there's equalizing circuitry in it.
A very large percentage of high end headphones are DF equalized - including all the big beyers for example. Since 1985.
Originally Posted by jarnauga /img/forum/go_quote.gif If it is diffuse-field equalized and you have a main cable that splits into two ones to reach both cups how do you make the mix of the signal? Into the big conector? I believe it could be very tricky to change this cable... |
ericj
- Aug 2, 2005
That's the other thing. They go on and on about the bigness of the driver, but the 56mm ring driver probably has a smaller driven surface than a 44mm dome driver.
Originally Posted by MaZa /img/forum/go_quote.gif I just started to wonder, how is the bass in this new type of dynamic driver design? Can it still reach deep AND hit hard enough? |
nikongod
DIY-ku
- Jan 24, 2005
The amp can create a DF for any headphone, but only if the proper EQ for that SPECIFIC headphone is built in.
IE: running a DT-48 on an amp with a DF EQ for an HD-600 is not DF, or even close to a decent sound...
diffuse field does not require mixing of the signal, only that the frequency response and certain phase shifts comply to certain standards.
I think you may be confusing cross-feed with DF, they are very different.
Originally Posted by jarnauga /img/forum/go_quote.gif Brochure says diffuse-field equalized. I believe since k240df there wasn't any cans with this feature because the amplifiers can handle that business |
powertoold
- Oct 14, 2007
It's definitely a proprietary connector:
Originally Posted by n_maher /img/forum/go_quote.gif I'm hopeful that we can get some confirmation about the connector that Senn chose to use at the headphones. It'll be a bummer in my book if they used some proprietary nonsense again. |
grawk
Itinerant Miscreant
- Mar 14, 2005
What about that picture says they're proprietary? There are a number of standard connectors that could fit that image.
linuxworks
Member of the Trade: Sercona Audio
- Oct 10, 2008
huh? you guys are still using pentiums??
(sorry)
back to the new-product-salvating, already in progress....
Originally Posted by scytheavatar /img/forum/go_quote.gif $325 is far too good a deal for the HD650, that's more like the price for the HD600. You know how Sennheiser works, they'll charge an unreasonable pentium outside of europe... |
(sorry)
n_maher
Resistorous Conflagorous
- Nov 20, 2004
The image says the jacks are specially made, a jack is not a plug.
jack
plug
jack
plug
ericj
- Aug 2, 2005
That must be where the confusion is. Because i can state for the record, for example, that the K240-DF has no equalization components in it. I've had mine completely disassembled for deep cleaning. It's just a different version of the same basic driver design found in the K140, K141, K240 Sextett, and K240-M. A version that sounds way better than most of those. To my ears anyway.
Originally Posted by nikongod /img/forum/go_quote.gif diffuse field does not require mixing of the signal, only that the frequency response and certain phase shifts comply to certain standards. I think you may be confusing cross-feed with DF, they are very different. |
noremedy
- Jul 29, 2007
These look amazing, and with regard to a higher price outside of Europe. Every other manufacturer of headphones fleece us if they come from America, its swings and roundabouts.
powertoold
- Oct 14, 2007
Well, if it's specially made for senn, then it's proprietary
Ok I need a lesson in reading comprehension.
grawk
Itinerant Miscreant
- Mar 14, 2005
No, if it's specially made for senn, it's custom. If it's not based on a standard, and they don't allow others to use it, it's proprietary.
les_garten
- Nov 6, 2008
From the vidz on Senn's website, it seems no doubt that Cardas will see a windfall here.
linuxworks
- Oct 10, 2008
this theme comes up each time a new camera (my other hobby) is intro'd. will they use standard connectors for power and remote-trigger or pull some proprietary nonsense.
users really like vendors to avoid proprietary connector types unless there's a *compelling* reason for it. usually, there is not - its simply a way to lock-out competitors and to force high prices on parts.
sometimes a company 'gets it' and does not force brand new proprietary connectors on us. most often, though, consumers 'feelings' are not quite taken into design or at least marketing consideration.. ;(
