- Feb 1, 2011
The 49990 is more balanced in its presentation. More detail and more pleasant than the 4562. Makes the 4562 feel overly bright and shouty in comparison. The 49990 is a step up.How does LM4562NA sound different to LME49990? I have the former in Matrix hpa-1 and was wondering if it's worth swapping for the later one?
You beat me to it! Two new V6 to choose from. One is supposed to more dynamic and detailed than the V5 and the other more musical? This will be interesting. Now we will have to start playing with the correct placement of each opamp. Which one for buffer vs I/V?Guys, it seems that there is a newborn baby in Burson family, or better two.
Have a look.
https://www.bursonaudio.com/products/supreme-sound-opamp-v6/
And it seems that there is a launch offer for the early birds.
Thanks, waiting v6iGuys, it seems that there is a newborn baby in Burson family, or better two.
Have a look.
sure thing but that's the removable extra socket that's fitted on top of the actual opamp pins, once it's off you can't tell where pin 1 is and it'll easily get stuck in your host so you'll end up with an opamp that doesn't show any indication of where pin 1 is. I guess putting a "1" on the bottom of the PCB was too much to ask.
truth is I got mine second hand from a n00b who fitted back that extra socket backwards by mistake so I found out first hand that v5's come with reverse voltage protection
Stay updated on Burson Audio at their sponsor profile on Head-Fi.
Just received LME49990 and maybe it's my head playing with me but highs might be just a little bit more clear, just listened to a few songs only. Just...The 49990 is more balanced in its presentation. More detail and more pleasant than the 4562. Makes the 4562 feel overly bright and shouty in comparison. The 49990 is a step up.
