SubL0ck
60 FPS games are fine, but i have a 240Hz monitor. Delay is huge like this.
I’ve never had it connected to a pc and don’t do any gaming, but there is no sync issue over optical from my tv watching moviesJust got myself the device. Wow, sounds amazing, really great there, but...
I'm really dissappointed. TA is pretty much unusable for any online competitive shooters as a sound card. The delay is massive! Tried the low gain trick, didn't work. The delay is may be slightly less noticable, but still there. Any possible solution?
Are you using 1.03 firmware?
Yes.Are you using 1.03 firmware?
I don't notive a delay playing 60FPS games or watching YT/Movies. It's the competitive shooters part that is problematic. CS: GO/Quake with FPS over 200/300 aren't playable. Guess i need another pair of headphones to play those using my EVGA soundcard. ShootI’ve never had it connected to a pc and don’t do any gaming, but there is no sync issue over optical from my tv watching movies
That may not have been a consideration back in 2016 when this dac/amp came out. Technology tends to change quite a lot in the span of 5 years.I don't notive a delay playing 60FPS games or watching YT/Movies. It's the competitive shooters part that is problematic. CS: GO/Quake with FPS over 200/300 aren't playable. Guess i need another pair of headphones to play those using my EVGA soundcard. Shoot
Apart from the fact the Sonys main focus was music not video/gamingThat may not have been a consideration back in 2016 when this dac/amp came out. Technology tends to change quite a lot in the span of 5 years.
Wonder if is the TA that has the problem receiving and handling or if is the pc having trouble keeping up sending the signal outI don't notive a delay playing 60FPS games or watching YT/Movies. It's the competitive shooters part that is problematic. CS: GO/Quake with FPS over 200/300 aren't playable. Guess i need another pair of headphones to play those using my EVGA soundcard. Shoot
Sorry, just saw this. Yeh, I ended up going with this:Did you end up finding one? To get more value out of my TA-ZH1ES I'm looking for the same thing. Please share any options and experiences you might have
