Just got 4 pair of AZLA XELASTEC today. I bought my normal size. They pair beautifully with my Fourte and LX. Once seated they seem to vanish. Thanks everyone who recommended.
The Official 64 Audio Thread | apex & tia Technologies
64audio now sells that premium leather case that comes with the Nio on their website. $49.99 + shipping and handling. Comes out to be just under $61 for me but that’s a bit too much imo. Just thought I’d share it’s available.
which module do you guys prefer with nio ?
m15 for mewhich module do you guys prefer with nio ?
Titienne
I think he was specifically asking for the NioM20 here with noir
Vitaly2017
I specifically added a
M15 but Fir O arrives next week.which module do you guys prefer with nio ?
My only concern is that the Sedna Short S falls out my ears quite easily (the standard length holds tight being a deeper insert). And the Xelastec is equivalent to the short. I guess I can always slide it down the stalk slightly so that it sits deeper. Hope it grips like crazy like you guys say it does - that Nio stalk is like a wet water slide for loose tips.yeah same size works for me .
PS. Is Amazon.com the cheapest source?
yeah im also back on m15 , i think its the most "balanced" of the 3M15 but Fir O arrives next week.
the xelastecs have some "sticky" surface .. so they fit pretty tight you even need some force to pull them out of your ear againMy only concern is that the Sedna Short S falls out my ears quite easily (the standard length holds tight being a deeper insert). And the Xelastec is equivalent to the short. I guess I can always slide it down the stalk slightly so that it sits deeper. Hope it grips like crazy like you guys say it does - that Nio stalk is like a wet water slide for loose tips.
what would be a good DAP (below $1500) paring with 64Audio Nio ? I have a diverse music taste - jazz, pop, Beatles, classical music and piano music?
Thank you for your feedback!
Titienne
My opinion might be a bit controversial, but I think I would get something like the Hiby R3 Pro / R5 and use the Lotoo Paw S1 with it. Very portable and sounds great! It would end up being well under $500 too!what would be a good DAP (below $1500) paring with 64Audio Nio ? I have a diverse music taste - jazz, pop, Beatles, classical music and piano music?
I saw good review for Lotoo Paw S1. But I don't know whether there is a huge difference from a mid price DAP. This set up is quite cost effective. ThanksMy opinion might be a bit controversial, but I think I would get something like the Hiby R3 Pro / R5 and use the Lotoo Paw S1 with it. Very portable and sounds great! It would end up being well under $700!
- Dec 26, 2019
M15which module do you guys prefer with nio ?
