JMR77
- Dec 20, 2016
I have them both right now. The trio may potentially be a bit technically superior. It's airier in the treble with a slightly more holographic soundstage. It's slightly recessed in the mids, which you don't care about. Bass hits well, though I would say it's slightly more of a subbass focus.
The nio though is more laid back than the trio, mostly attributed to it being a warmer sound overall and has more laid back treble. Treble is still detailed just maybe without the extra sparkle/air. It also has more forward mids than the trio. Bass quantity is larger than the trio (with m15 module). Soundstage is more width than holographic, though it's really not that different overall go the trio (but then again most soundstage changes between iems are pretty minor anyways).
Personally, since I got the nio, I haven't been using my trio as I just really enjoy the sound from the nio. But I think if you are looking for bass and treble, (v shaped is what I'm hearing), the trio may be the better choice. But if looking for more relaxed and warm, the nio is fantastic and also 600 dollars cheaper if buying new... Though I am sure lower pricef trios can be had used (like mine will almost certainly be when I put it up for sale), while the nio is so new and stock still so low that it may be a while before they start showing up for sale used.
I pretty much agree with this comparison.
I just compared both Nio and Trió with 4 songs.
Clearly the Trió offers a bit more clarity with detail retrieval because it has more treble. But with Nio you can change modules and the MX module changes the overall signature notably. So by using different tips and modules you have more versatility with Nio.
With the Nio I just changed the stock silicon tips with Comply ones and the sound out of the M15 module changed more than I thought, rather than sub bass being the protagonist, a "mass" of (still good) bass was more present and soundstage felt less expansive/airy. Then swapping to the MX module with Comply tips the sound opened again (more air and soundstage) and sub bass was more distinguishable again also midrange (specially) and treble took the lead. Using Comply tips with the MX module was close to using stock silicon tips with the M15 module to my ears, but with better bass impact.
