SupperTime
Where could one buy just that oneThe lower the number, the less the bass, so FIR module N13 would be the least bass.
Thank you sir, do you know where they would stock the N13 only. Just looking for that because of least bassAlso, these numbers represent approximately the amount of noise isolation in dB. For example, M15 is -15dB of noise isolation, M20 is -20dB of noise isolation. Less noise isolation, less seal, and less bass impact. And the other way around with more noise isolation.
How much better is the U18t than the U12t in terms of the strengths of the U12t?
I’m listening to Vikingur Olafsson’s “For Johann” off of that amazing Bach rework album and I’m again floored by how perfect the piano sounds with the airy echos and clicking clack of the mechanicals and little sounds in the room.., It’s just the best I’ve ever heard this piece, proclaiming in my head that I’ve hit the end of the road and will have to be satisfied to explore lower price iems for my work set...
Then the audio”phool” in me thinks... could it be even better with the U18t?
Thinking of getting a u12t. What's the bass like and are there any qc problems with them before I pull the trigger!
rather different audio experience, u18t is more immediate, whereas u12t feels as though you are a couple of rows back. I like both but preferred u12t for post rock, modern classical and ambient, while the 18t for something that needs a “denser“ presentation, ymmv.
even within the same genre, sigur ros sounds sublime on the U12t, but Mogwai sounds more emotive via the U18t, whereas U12t’s slightly shelved down mids made for a more sedate, less full on experience.
we have similar taste in music, saw Richter 3 times now, also saw Hauschka in Toronto, now looking forward to seeing AWVFTS this april!.
how far do you guys attached the final e tips? til the end of the nozzle? or a little bit of clearance
