KuroKitsu
15% off on the A12t is a bit much for me but the A6t? Definitely worth consideration. Maybe even some customization :3
Ive heard that a lot about the 12t, I suspect part of the reason is Tia allowing them to devote more BAs to the lows. I considered it since the Zeus felt like bass was lacking, but I don't think the 12t would bridge that small change I want.I really liked the U12t when I got to audition them for the week, but of course you need a really good seal which is why I'm going for the CIEM version. I struggled with getting a good seal, but when I got a good seal, the U12t had great bass impact with no muddiness and the soundstage was wide and very transparent. Others have said that the A12t is much better than the U12t because it always has a good seal.
@Deezel177
Daniel, have you tried the A6t with Leo II?
Also the PWaudio 1960 is an excellent cable for the A6t, not too bright but with an excellent resolution.The Leo II gives the A6t excellent authority in the bass and some much-needed richness in the lower-mids. But, I reckon the lower-treble is more neutral-bright than I'd like. It's not artificial-sounding or harsh at all, but I feel like the treble and bass could be better cohered by way of a warmer cable or source. So unless your DAP has a particularly smooth and feathered lower-treble, I'd probably maintain pairing the A6t with a more neutral/warm cable. Despite being inferior technically, the stock one is an excellent tonal match IMO, if that helps.
The 1960 is literally good with anything. It better be for that price.Also the PWaudio 1960 is an excellent cable for the A6t, not too bright but with an excellent resolution.
Some people saying that the u12t’s mids are recessed. Is that true?
Stay updated on 64 Audio at their sponsor profile on Head-Fi.
okThe thing with the AK device is that, does it have enough juice to really get the N8 to perform well? In terms of power output i do not see the AK SK1k series as being the most powerful players out there, and the N8 does scale very well when you feed it with more juice.
To illustrate, I thought the N8 sounded a little dull on the SP1K copper, lifeless for lack of a better word. It improved when switched over to the 1Z. I've not had time to test it on the new LPG touch, but I have high expectations for it. Same goes too for the new cayin player.
The N8 too seems to react to cable pairing too. I had a effect horus cable lying around that I thought I might use with it since I thought it might it a little bit more transparency, but it totally threw the signature off. To me, good ole' copper seems to go best with the N8.
In short, the N8 seems remarkably sensitive to gear changes. I did not experience this large a change when trying out other iem demo units, and I honestly find myself a little surprised that changing cables could make that much of a difference.
Which means now that I once again dont have a use for that horus cable. Bought it on a whim based on the brand reputation and hype, and I regret it. Maybe I should look into selling it rather than let it collect dust.
